  4. problem with waypoints
11 Posts 4 Posters 3.0k Views 1 Watching
  • Albyus
    Albyus
    Albyus
    Hi, yesterday I created a route with about 5 waypoints. Due to a problem with the route, I had to skip the second one and then for the whole journey it wanted me to go back to pass by that waypoint. You can understand that in the end I had to stop the navigation. But in these situations, how should I solve the problem? Thanks !!!!!
    Ton Machielsen 1 Reply Last reply
    • Albyus Albyus
      Ton Machielsen
      Ton Machielsen
      Ton Machielsen
      @Albyus If it's a route, you can skip the waypoint and the app will route you to the next.
      Albyus 1 Reply Last reply
      • Ton Machielsen Ton Machielsen
        Albyus
        Albyus
        Albyus
        @Ton-Machielsen Why then was he asking me to go back?
        Marinus van Deudekom Ton Machielsen 2 Replies Last reply
        • Albyus Albyus
          @Albyus was that a shapingpoiunt (blue drop) or a viapoint (hand shape)
          • Albyus Albyus
            Ton Machielsen
            Ton Machielsen
            Ton Machielsen
            @Albyus Because your next waypoint ACCORDING TO THE APP (not according to you) was probably behind you. You can see which is your next waypoint on the upper right corner of the screen.
            I'm glad you posted this ask. It proves to me that i am not the only one struggling with waypoint skipping.
            Albyus 2 Replies Last reply
              Albyus
              Albyus
              Albyus
              @Marinus-van-Deudekom hand-shaped
                Albyus
                Albyus
                Albyus
                @Ton-Machielsen hahahaha, no...
                  Albyus
                  Albyus
                  Albyus
                  @Ton-Machielsen are you referring to the smartphone application?
                  • Albyus Albyus
                    Ton Machielsen
                    Ton Machielsen
                    Ton Machielsen
                    @Albyus Yes
                      @Albyus Yes
                      Albyus
                      Albyus
                      Albyus
                      @Ton-Machielsen do you have a screen where you can see the next waypoint? Just to understand
                      • Albyus Albyus
                        @Albyus said in problem with waypoints:
                        Hand shaped waypoints are specifically intended NOT to be auto-skipped (mandatory waypoint). So you will have to skip it manually if you do not intend to visit it.
                        Albyus
                        Albyus
                        Ton Machielsen
                        Ton Machielsen
                          John Matthews 0
                          John Matthews 0
