  4. problem with waypoints
11 Posts 4 Posters 1.6k Views 1 Watching
  • Albyusundefined Offline
    Albyus
    Hi, yesterday I created a route with about 5 waypoints. Due to a problem with the route, I had to skip the second one and then for the whole journey it wanted me to go back to pass by that waypoint. You can understand that in the end I had to stop the navigation. But in these situations, how should I solve the problem? Thanks !!!!!
    Ton Machielsenundefined 1 Reply Last reply
    • Albyusundefined Albyus
      Ton Machielsenundefined Offline
      Ton Machielsen
      @Albyus If it's a route, you can skip the waypoint and the app will route you to the next.
      Albyusundefined 1 Reply Last reply
      • Ton Machielsenundefined Ton Machielsen
        Albyus
        @Ton-Machielsen Why then was he asking me to go back?
        Marinus van Deudekomundefined Ton Machielsenundefined 2 Replies Last reply
          @Albyus was that a shapingpoiunt (blue drop) or a viapoint (hand shape)
            Ton Machielsen
            @Albyus Because your next waypoint ACCORDING TO THE APP (not according to you) was probably behind you. You can see which is your next waypoint on the upper right corner of the screen.
            I'm glad you posted this ask. It proves to me that i am not the only one struggling with waypoint skipping.
            Albyusundefined 2 Replies Last reply
              Albyus
              @Marinus-van-Deudekom hand-shaped
                Albyus
                @Ton-Machielsen hahahaha, no...
                  Albyus
                  @Ton-Machielsen are you referring to the smartphone application?
                    Ton Machielsen
                    @Albyus Yes
                      @Albyus Yes
                      Albyus
                      @Ton-Machielsen do you have a screen where you can see the next waypoint? Just to understand
                        @Albyus said in problem with waypoints:
                        Hand shaped waypoints are specifically intended NOT to be auto-skipped (mandatory waypoint). So you will have to skip it manually if you do not intend to visit it.
                        Albyusundefined
                        Albyus
                        Ton Machielsen
                        • free ride
                          Ewout 2undefined
                          Ewout 2
                        • Strange behavior
                          Aiello antoninoundefined
                          pehaundefined
                          peha
                          2.4k
                        • scenic route inkorten
                        • snelheid zichtbaar
                        • cant use app just to view map when riding
                          Donovan Smithundefined
                          Donovan Smith
                        • Reverse route
                          white.mouseundefined
