  4. Route ignores obvious left turn
24 Posts 5 Posters 8.9k Views 3 Watching
  • twinfan Offline
    twinfan Offline
    twinfan
    Greetings,
    I am a seasoned Garmin BaseCamp/Zumo XT user but just started with MRA using a Basic account. I did this in order to generate routes while on a trip using my iPad if for some reason my original plans change. This happened last fall when our route took us into areas with heavy forest fire smoke. We canceled our original trip plans and headed the other direction. I created new routes directly on the Zumo which was cumbersome to say the least. I like what I'm seeing so far with MRA and can envision moving to it exclusively as I get more experience with it.
    I created a day trip on my iPad and found a situation where MRA would not follow the obvious road. Even when I added shaping points (locations shown by red dots between shaping points 5 and 6) it created convoluted paths to get to them but not follow the simplest, most direct route. It doesn't seem likely this is a map choice problem, that is the free OSM vs. the subscription HERE map. Could it just be an error in the OSM map? My only avoidance is unpaved roads. BTW, this route loaded into the Zumo makes the correct turn as you would expect between the two shaping points.
    Tom
    alt text
    • Mopetenpit Offline
      Mopetenpit Offline
      Mopetenpit
      This seems to be a problem with the OSM map. If I change the standard map from OSM to Here or Tomtom, the route works as expected. However, changing from OSM to Here/Tomtom is only possible in the Gold version.
      • Next Stop Offline
        Next Stop Offline
        Next Stop
        As @Mopetenpit said, the Here maps seems to work fine, so presume it's an issue with OSM
        • martin-phogel.de Offline
          martin-phogel.de
          I don't think it's because of the OSM data.
          There are two potential limitations: A railway barrier and a U-turn restriction, but neither should prevent a left turn:
          Other planning programmes based on OSM allow this:
          This is probably due to the route engine (API) MRA uses.
          • twinfan Offline
            twinfan Offline
            twinfan
            Thanks all for the quick replies. A map problem was my conclusion, too. I've made that left turn many times and there are no restrictions.
            Is there a means to report this problem? In the past I've done so with Garmin's maps.
            Tom
            • twinfan Offline
              twinfan Offline
              twinfan
              Answered this last question by creating an OSM account and posting a note at that location.
              • twinfan twinfan
                martin-phogel.de
                @twinfan said in Route ignores obvious left turn:
                What exactly do you mean by that?
                • twinfan Offline
                  twinfan Offline
                  twinfan
                  OSM provides for problem reporting and map fixes. I made this note:
                  alt text
                  • twinfan twinfan
                    alt text
                    martin-phogel.de
                    I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
                    As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
                    • twinfan Offline
                      twinfan Offline
                      twinfan
                      @Martin-Wilcke said in Route ignores obvious left turn:
                      From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
                      • twinfan twinfan
                        martin-phogel.de
                        I have taken a closer look at this spot.
                        The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
                        I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
                        • twinfan Offline
                          twinfan Offline
                          twinfan
                          Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
                          • twinfan Offline
                            twinfan Offline
                            twinfan
                            I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                            ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                            • twinfan twinfan
                              martin-phogel.de
                              wrote on last edited by martin-phogel.de
                              #14
                              Here is an overview of all valid keys, their values, meaning and examples:
                              https://wiki.openstreetmap.org/wiki/Map_features
                              Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                              It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                              https://forum.myrouteapp.com/post/58690
                              • twinfan twinfan
                                martin-phogel.de
                                #15
                                @twinfan
                                According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                                So, I recommend making the following changes (for both directions):
                                • Delete the lift gate barrier:
                                Add the "two-half barrier arm" attribute to the railway crossing:
                                • twinfan Offline
                                  twinfan Offline
                                  twinfan
                                  Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                                  • twinfan Offline
                                    twinfan Offline
                                    twinfan
                                    I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                                    Tom
                                    • twinfan twinfan
                                      martin-phogel.de
                                      @twinfan
                                      https://www.openstreetmap.org/note/4613925
                                      Cool! šŸ‘
                                      • twinfan twinfan
                                        Tom
                                        martin-phogel.de
                                        @twinfan
                                        It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                                        Brian McG 1 Reply Last reply
                                        • twinfan Offline
                                          twinfan Offline
                                          twinfan
                                          @Martin-Wilcke, thanks for checking and nice to see it worked!
                                          Mopetenpit
                                          Mopetenpit
                                          martin-phogel.de
                                          martin-phogel.de
                                          Next Stop
                                          Next Stop
                                          twinfan
                                          twinfan
                                          • The slow death of Zumo...
                                          • Route Breakdown
                                          • Feature Request: Map Contrast & Road Visibility in Navigation⁠
                                          • MRA Touring Romania Group
                                          • I can't see Road Closures
                                            Lary
                                            Lary
                                            Arno van Lochem - Senior RX
                                          • Schermresoluties, beeldverhoudingen en schermgroottes
                                            Carl Lee
                                            Carl Lee
                                            635
