  4. Route ignores obvious left turn
24 Posts 5 Posters 9.5k Views 3 Watching
  • twinfan twinfan
    Answered this last question by creating an OSM account and posting a note at that location.
    martin-phogel.de
    martin-phogel.de
    martin-phogel.de
    @twinfan said in Route ignores obvious left turn:
    What exactly do you mean by that?
    • twinfan
      twinfan
      twinfan
      OSM provides for problem reporting and map fixes. I made this note:
      alt text
      • twinfan twinfan
        alt text
        martin-phogel.de
        martin-phogel.de
        martin-phogel.de
        I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
        As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
        • twinfan
          twinfan
          twinfan
          @Martin-Wilcke said in Route ignores obvious left turn:
          From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
          • twinfan twinfan
            martin-phogel.de
            martin-phogel.de
            martin-phogel.de
            I have taken a closer look at this spot.
            The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
            I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
            • twinfan
              twinfan
              twinfan
              Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
              • twinfan
                twinfan
                twinfan
                I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                • twinfan twinfan
                  martin-phogel.de
                  martin-phogel.de
                  martin-phogel.de
                  #14
                  Here is an overview of all valid keys, their values, meaning and examples:
                  https://wiki.openstreetmap.org/wiki/Map_features
                  Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                  It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                  https://forum.myrouteapp.com/post/58690
                  • twinfan twinfan
                    martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    @twinfan
                    According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                    So, I recommend making the following changes (for both directions):
                    • Delete the lift gate barrier:
                    Add the "two-half barrier arm" attribute to the railway crossing:
                    • twinfan
                      twinfan
                      twinfan
                      Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                      • twinfan
                        twinfan
                        twinfan
                        I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                        Tom
                        • twinfan twinfan
                          martin-phogel.de
                          martin-phogel.de
                          martin-phogel.de
                          @twinfan
                          https://www.openstreetmap.org/note/4613925
                          Cool! 👍
                          • twinfan twinfan
                            Tom
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            @twinfan
                            It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                            Brian McG 1 Reply Last reply
                            • twinfan
                              twinfan
                              twinfan
                              @Martin-Wilcke, thanks for checking and nice to see it worked!
                                @twinfan
                                @Martin-Wilcke the refresh cycle is not to do with OSM,
                                an edit to the OSM map can appear & be publicly available within a matter of hours.
                                As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                                it can lag by many many months as you have seen.
                                Here map data can take from a few days to several weeks to update
                                MRA update their Here data a lot more regularly, I think with every MRA update
                                • Brian McG Brian McG
                                  martin-phogel.de
                                  martin-phogel.de
                                  martin-phogel.de
                                  @Brian-McG said in Route ignores obvious left turn:
                                  I know. With other apps, this change was visible within a few days.
                                  That's what I mean by
                                  Does MRA mirror the complete OSM map data on their own server?
                                    Apologies if I misinterpreted your previous post, terminology often does not translate well.
                                    e.g. for me the term "mirror" implies the same data is available in 2 or multiple locations at similar times.
                                    So I would not use "mirror" regarding MRA's OSM data as it is out of date for a considerable amount of time compared to the data available from OSM. It is why I used the term "snapshot".
                                    Sorry, I do not know where or how MRA host / store their data, I would just be guessing.
                                    Maybe someone else has the answer?
                                      martin-phogel.de
                                      martin-phogel.de
                                      martin-phogel.de
                                      @Brian-McG
                                      If we're being precise, we're not talking about the map data that is displayed, but rather about the data used for routing.
                                      I assumed that MRA uses a service (i.e. a REST API) that takes over the routing and thus also accesses a server on which the routing data is stored.
                                      If MRA stores the routing data on its server (yes, as a snapshot), then the developers must also have implemented a routing engine (presumably based on one of the available frameworks).
                                      Regardless of how it is technically implemented, the OSM data is obviously updated in long cycles. However, we should bear in mind that MRA focuses on HERE data, which is why the time lag in OSM data is not so important in my view.
                                      martin-phogel.de
                                      martin-phogel.de
                                      Next Stop
                                      Next Stop
                                      Mopetenpit
                                      Mopetenpit
                                      twinfan
                                      twinfan
                                      • Custom POI color and icons
                                      • File en omrijden
                                      • A11 Making the Algorithm More Visible – Overview and Planner File
                                      • File / Creation date
                                        Robineke
                                        Robineke
                                        308
                                      • F003 POI Folder & group missing in the app
                                      • F005 Menu covered
                                        12.8k
