  4. Route ignores obvious left turn
24 Posts 5 Posters 8.6k Views 3 Watching
  • twinfan twinfan
    OSM provides for problem reporting and map fixes. I made this note:
    alt text
    martin-phogel.de Offline
    martin-phogel.de
    @twinfan said in Route ignores obvious left turn:
    I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
    As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
    • twinfan Offline
      twinfan Offline
      twinfan
      @Martin-Wilcke said in Route ignores obvious left turn:
      From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
      • twinfan twinfan
        martin-phogel.de
        I have taken a closer look at this spot.
        The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
        I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
        • twinfan Offline
          twinfan Offline
          twinfan
          Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
          • twinfan Offline
            twinfan Offline
            twinfan
            I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
            ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
            • twinfan twinfan
              martin-phogel.de
              #14
              Here is an overview of all valid keys, their values, meaning and examples:
              https://wiki.openstreetmap.org/wiki/Map_features
              Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
              It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
              https://forum.myrouteapp.com/post/58690
              • twinfan twinfan
                martin-phogel.de
                @twinfan
                According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                So, I recommend making the following changes (for both directions):
                • Delete the lift gate barrier:
                Add the "two-half barrier arm" attribute to the railway crossing:
                • twinfan Offline
                  twinfan Offline
                  twinfan
                  Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                  • twinfan Offline
                    twinfan Offline
                    twinfan
                    I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                    Tom
                    • twinfan twinfan
                      martin-phogel.de
                      @twinfan
                      https://www.openstreetmap.org/note/4613925
                      Cool! 👍
                      • twinfan twinfan
                        Tom
                        martin-phogel.de
                        @twinfan
                        It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                        Brian McG 1 Reply Last reply
                        • twinfan Offline
                          twinfan Offline
                          twinfan
                          @Martin-Wilcke, thanks for checking and nice to see it worked!
                            @twinfan
                            Brian McG Offline
                            Brian McG Offline
                            @Martin-Wilcke the refresh cycle is not to do with OSM,
                            an edit to the OSM map can appear & be publicly available within a matter of hours.
                            As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                            it can lag by many many months as you have seen.
                            Here map data can take from a few days to several weeks to update
                            MRA update their Here data a lot more regularly, I think with every MRA update
                            • Brian McG Brian McG
                              martin-phogel.de
                              @Brian-McG said in Route ignores obvious left turn:
                              I know. With other apps, this change was visible within a few days.
                              That's what I mean by
                              Does MRA mirror the complete OSM map data on their own server?
                                Brian McG Offline
                                Brian McG Offline
                                Apologies if I misinterpreted your previous post, terminology often does not translate well.
                                e.g. for me the term "mirror" implies the same data is available in 2 or multiple locations at similar times.
                                So I would not use "mirror" regarding MRA's OSM data as it is out of date for a considerable amount of time compared to the data available from OSM. It is why I used the term "snapshot".
                                Sorry, I do not know where or how MRA host / store their data, I would just be guessing.
                                Maybe someone else has the answer?
                                  martin-phogel.de
                                  @Brian-McG
                                  If we're being precise, we're not talking about the map data that is displayed, but rather about the data used for routing.
                                  I assumed that MRA uses a service (i.e. a REST API) that takes over the routing and thus also accesses a server on which the routing data is stored.
                                  If MRA stores the routing data on its server (yes, as a snapshot), then the developers must also have implemented a routing engine (presumably based on one of the available frameworks).
                                  Regardless of how it is technically implemented, the OSM data is obviously updated in long cycles. However, we should bear in mind that MRA focuses on HERE data, which is why the time lag in OSM data is not so important in my view.
                                  Next Stop
                                  Next Stop
                                  Mopetenpit
                                  Mopetenpit
                                  martin-phogel.de
                                  martin-phogel.de
                                  twinfan
                                  twinfan
                                    Steve Jarrell
                                    Steve Jarrell
                                    9.5k
                                  • Map definition/ clarity
                                  • Hi Folks
                                    285
                                    1.0k
                                  • Startpagina Route Lab
