  4. Not zooming in on junctions
4 Posts 3 Posters 1.0k Views 2 Watching
  • Rob Kelley
    Rob Kelley
    Rob Kelley
    I just can't workout how to get MRA Nav to zoom in on junctions and roundabouts, or even just zoom in closer in general.
    In this scrn shot there a few roundabouts which I'd like it to zoom in on, does MRA Nav do this?
    Zoom Adjustments is set to 'On', I tried the other options but no luck.
    Thanks
    GSA1250
    HD Street Glide
    XT500 x 2
    • Rob Kelley Rob Kelley
      Thanks
      @Rob-Kelley There are 3 camera views. Top down, North up and Dynamic.
      Top down has a fixed zoom level which you can set. North up and Dynamic have auto zoom that you set in Navigation settings, Map layer.
      Tapping the compass icon scrolls through the 3 views.
      The order of views is:
      Top down.
      North up.
      Dynamic.
      North up is easy to recognise as the yellow compass needle points up and the map does not rotate.
      I will also say that a long press on the compass will show your entire route, a quick tap returns it.
      You can set Zoom adjustments to come in with speed, proximity to instructions or both. And with the slider controls you can set by how much.
      Rob Kelley 1 Reply Last reply
        Top down.
        North up.
        Dynamic.
        Rob Kelley
        Rob Kelley
        Rob Kelley
        @Nick-Carthew
        Thanks.
        After I posted I did wonder if it may have been that pesky compass button, I guess I must have been in Top Down mode, I'll try Dymanic mode.
        I would be good if it briefly flashed up on the screen which view mode it was in when tapping the compass.
        GSA1250
        HD Street Glide
        XT500 x 2
          @Nick-Carthew
          Thanks.
          @Rob-Kelley said in Not zooming in on junctions:
          That's actually not a bad idea. It happens more often that people are confused by this.
          Rob Kelley
          Rob Kelley
            Jack 13
            Jack 13
            473
          • Myrouteappstay
          • Route uploaden
            Johan 5q
            Johan 5q
          • Track colors by section.
            Rolf Engelsman
            Rolf Engelsman
            Marcel Versluis
            Marcel Versluis
