  4. Remotek-One Exchange of experiences
105 Posts 11 Posters 88.5k Views 8 Watching
  • Hubert Thoring
    @CD130 : du kommst aber bestimmt nicht zum eingeblendeten Menü „Nein / Navigieren „ um die Route fortzusetzen 🤔
    But you certainly won't get to the displayed menu "No / Navigate" to continue the route 🤔
    • Hubert Thoring
      iOS is confirmed with +
      I can't get into the additional displayed menu with the keyboard to answer the question to continue.
      • ConiKost ConiKost
        @Hubert-Thoring said in Remotek-One Exchange of experiences:
        Das wie im Video dargestellt wird wohl so mit keiner BT Tastatur und auch nicht mit dem WW gehen.
        Bezogen worauf? Auf die Nachfragemeldung?
        Die MRA Menü Ebenen greifen nicht zusammen, ob man das noch nachträglich in einem MRA Update berücksichtigt glaube ich nicht.
        Naiv hätte ich erwartet, dass das mit sehr wenig Aufwand realisierbar sein sollte. (Was ich so aus der Entwicklung selbst kenne) (Bezogen auf die Nachfragemeldung wohl?)
        @CD130 said in Remotek-One Exchange of experiences:
        Here, everything works perfectly on iOS. I have the latest firmware installed on the Remotek-One, and I’ve only set the input settings to Remotek One within the MRA app. I haven’t changed anything within iOS itself.
        So you can type with Remotek One with virtual keyboard, but on iOS?
        @ConiKost I use the remote quite intensively and rarely experience this issue. That’s mainly due to the way I use it. I make sure the route is started before placing my phone in the mount, and any tasks that require typing I apparently do outside the range of the remote. Because of that, I don’t really run into this problem in practice, even though it does occur when I test for it.
        Unfortunately, this is caused by iOS. As far as I know, there’s currently nothing that can be done about it.
        ConiKost 1 Reply Last reply
        • CD130 CD130
          ConiKost
          ConiKost
          ConiKost
          Well, since keyboard does not work for me on Android with Remotek, this can't be an iOS only issue?
          Shiny!
          • CD130 CD130
            silberfuchs67
            silberfuchs67
            silberfuchs67
            This is exactly my experience, too.
              Zum Video: das kenne ich genau so 😜
              @ConiKost
              • Die MRA Menü Ebenen greifen nicht zusammen, ob man das noch nachträglich in einem MRA Update berücksichtigt glaube ich nicht.
              Ich nutze das gar nicht, das Navigieren und das Zoomen und WP überspringen ist ein muss und das funktioniert wunderbar mit der Remotek One.
              Die anderen Menü Eingaben macht man besser im stehen, ….
              silberfuchs67
              silberfuchs67
              silberfuchs67
              Korrekt - bisher funktioniert dies einwandfrei - auch auf dem DMD Device T665.
              • Hubert Thoring
                @Corjan-Meijerink : For info of the menus 1.) and 2.) s. Picture .
                When applying, you can't get to the menu 2.) = Additional menu, because the operation by a WW or a BT keyboard like the Remotek One remain in the menu 1.) = Main menu
                Can't that be changed?
                • silberfuchs67 silberfuchs67
                  ConiKost
                  ConiKost
                  ConiKost
                  @silberfuchs67 said in Remotek-One Exchange of experiences:
                  Das tut mir auch alles super 🙂
                  @Corjan-Meijerink See Demo video in https://forum.myrouteapp.com/topic/7331/remotek-one-exchange-of-experiences/77?_=1775035025602
                  @Hubert-Thoring Damit ich das richtig verstehe: Die Tastatureingabe mit der Remotek One funktioniert unter iOS bei euch genauso wenig, ja?
                  Shiny!
                  • Hubert Thoring
                    @ConiKost
                    Sie funktioniert, ich komme nur nicht in Menü 2.) s. Bild weil es im Menü 1.) verbleibt.
                    Im Menü 1.) kann ich alles bedienen und über Pfeiltaste anwählen und mit + z.B. dann bestätigen …
                      @ConiKost
                      ConiKost
                      ConiKost
                      ConiKost
                      Also funktioniert 1) bei dir korrekt und beim Wechseln durch das Hauptmenü scrollt es mit?
                      Ich bezog mich aber mit der Tastatur auf 3), wenn man mit der Remotek was eingeben will.
                      Shiny!
                      • Hubert Thoring
                        Dann musst Du bzw. ich Bluetooth ausschalten, dann die Eingabe über das Handy und der Display Tastatur ausführen und dann wenn fertig Bluetooth wieder einschalten. Das wird bei iOS so beschrieben !
                          ConiKost
                          ConiKost
                          ConiKost
                          Reden wir aneinander vorbei? Wenn ich Bluetooth abschalten würde, geht nur noch per Touch. Per Touch kann ich die virtuelle Tastatur immer bedienen, egal ob die Remotek verbunden ist oder nicht. Das meine ich aber überhaupt nicht. Sondern per Pfeiltasten der Remotek die virtuelle Touch Tastatur bedienen mit der Remotek. Das soll ja laut Handbuch gehen und in der Remotek App habe ich dafür die Berechtigungen freigegeben?
                          Shiny!
                          • Hubert Thoring
                            Dann haben wir uns missverstanden, mach mal ein Foto davon … ‼️
                              ConiKost
                              ConiKost
                              ConiKost
                              Dann haben wir uns missverstanden, mach mal ein Foto davon … ️
                              Ich glaube langsam, dass hier ein Missverständnis meinerseits liegt.
                              Meine (naive) Annahme wäre, dass das Anzeigen der Virtuellen Tastatur (was man in der Remotek App konfiguriert) bei Nutzung der Remotek auch bedeutet, dass man mit den Pfeiltasten die virtuelle Tastatur navigieren kann. (Ähnlich wie früher auf einem SNES mit Gamepad). Ist aber nicht schlimm, das ist für mich kein Feature, was ich brauche.
                              Shiny!
                              • MartinW
                                Mal was ganz anderes: Was für einen Schraubendreher braucht man für den Knopfzellenwechsel? T5, T6?
                                • Hubert Thoring
                                  #96
                                  Ich weiß es gar nicht, Uhrmacher Werkzeug geht immer , … die Batterie hält aber mehr als zwei Jahre
                                  MartinW 1 Reply Last reply
                                    wrote on last edited by MartinW
                                    #97
                                    @Hubert-Thoring
                                    So ein Uhrmacher-Set habe ich auch, mit verschiedenen Schlitz- und Kreuzdrehern.
                                    Bei der Remotek sind aber Torx Schrauben verbaut und da hätte ich schon gerne das passende Werkzeug - ich bin da pingelig 🙂
                                    • Hubert Thoring
                                      Ich schaue mal du hast Recht TX-8 passt
                                        @Hubert-Thoring
                                        Super, danke dir!
                                        • ConiKost
                                          ConiKost
                                          ConiKost
                                          Kann es sein, dass sich das geändert hat? Die beiden Schrauben zum Öffnen der Remotek sind bei mir TX7. TX8 ist zu groß bei mir. Und die Schraube zum Sichern in der Halterung ist TX10.
                                          Shiny!
                                          • 4
                                          • 5
                                          • 6
                                          ConiKost
                                          ConiKost
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          Westerwald_Rider
                                          Westerwald_Rider
                                          Lynchy67
                                          Lynchy67
                                            Kudee
                                            Kudee
                                          • Newsletter optimisation
                                            TomOnTour
                                            TomOnTour
                                          • Planner: Convert batches of shaping points into via points and vice versa
                                          • Weather: rain colors
