  4. How can I correct incorrect routing?
5 Posts 3 Posters 1.2k Views 1 Watching
  • Nicolaj
    Nicolaj
    Nicolaj
    Hi all,
    I'm new to the app. I was working on a route on the Route Planner website with a start point in North London.
    I found an intersection where the planner gives an incorrect route (the intersection of B106 with A109). The blue circled deviation in the second picture is unnecessary. For that intersection, traffic can proceed directly across without having to make a detour. Is there a way for me to correct this in the app or otherwise? I'm familiar with that intersection and have passed through it a dozen times.
    Thanks,
    Nicolaj
    • Nicolaj Nicolaj
      Hi all,
      Thanks,
      Nicolaj
      @Nicolaj The OpenStreetMap that you are planning your route on does not want to go straight over at Bounds Green. Both the HERE and TomTom planning maps do go straight over.
      My example shows me using the HERE planning map with the OpenStreetMap overlay selected.
      There is obviously a fault with the OSM map.
      Nicolaj 1 Reply Last reply
        Nicolaj
        Nicolaj
        Nicolaj
        @Nick-Carthew Thank you - I'll try that out. I'm still on the steep part of the learning curve 🙂
        • Nicolaj Nicolaj
          Hi all,
          Thanks,
          Nicolaj
          @Nicolaj, you can submit changes to OSM at openstreetmap.org. I think you will need to register first.
          • Nicolaj Nicolaj
            @Nicolaj Using the correct planning map for your device is important. If you use a Garmin based navigation device including MRA Navigation Next you should use the HERE planning map, If your device is TomTom based then the TomTom planning map is the correct one. You can use any of the overlay maps over the top of the planning map, think of the overlays as clear sheets with extra information for the planning map. Your route is calculated and drawn on the planning map.
            Nicolaj
            Nicolaj
            • Route wordt afgesneden
              Wim Hompes
              Wim Hompes
              Pierre c
              Pierre c
            • OSM Routing with MRA
              Herman Veldhuizen
              Herman Veldhuizen
