  3. Circular route, changing starting point
3 Posts 2 Posters 903 Views 2 Watching
  • Tony 13
    Tony 13
    Tony 13
    I have just picked up a circular route from the library which has 73 waypoints.
    Rather than starting at point 1 (why would I?) I would like to start near point 50.
    Is there a quick way to re-order all the waypoints?
    In the past I manually moved each one - which worked in the end
    Tony
    • Tony 13 Tony 13
      Tony
      @Tony-13
      Make a copy of the route to work with.
      Select the waypoint you want to start at and open the properties. Click on the flag to make this point your starting point. Correct any other waypoints as necessary.
      • Nick Carthew Nick Carthew moved this topic from [Web] Suggestions and Discussion on
      • Tony 13
        Tony 13
        Tony 13
        Easy! Thank you. I wondered what that icon did.
        Tony 13
        Tony 13
          3.1k
          Chris 4p
          Chris 4p
        • Navigating on NEX
          LluĂ­s Casals
          LluĂ­s Casals
        • v6, tankstation
          superg
          superg
