  3. Multiple routes, in a route
11 Posts 5 Posters 2.2k Views 2 Watching
  • RGDan59
    RGDan59
    RGDan59
    I'm new to MyRoute, but am creating a master route heading from York, PA to Milwaukee, WI, for the Harley Davidson 120th Homecoming Festival. I just realized I can insert small "daily ride routes" into my master route.
    I noticed that these small rides routes appear in yellow. Is there a way to change their color, and how do I save the master route whereby the daily rides will still appear in the master? My apologies if my terminology is off.
    Thanks,
    Dan
    Nick Carthew RetiredWingMan 2 Replies Last reply
    • RGDan59 RGDan59
      Thanks,
      Dan
      @RGDan59 Make a copy of the master route and if you have a Gold RoutePlanner account you can use the split tool to split the copy into individual daily routes.
      RGDan59 1 Reply Last reply
      • RGDan59 RGDan59
        Thanks,
        Dan
        @RGDan59 it sounds like you want to merge multiple routes in to a single route. As far as I know there is no utility to do that. You have to manually add the waypoints into your master route.
        Nick Carthew Rob Verhoeff HABVEN aka MrMRA 3 Replies Last reply
          @Doug-Robinson Merging routes is possible. Type merge into the support search box.
          https://www.myrouteapp.com/support
          Rob Verhoeff RGDan59 2 Replies Last reply
            This post is deleted!
              @Nick-Carthew that was slipped away in my head... Thnx for reminding!
                @Doug-Robinson
                https://www.mrmra.com/faq.phtml
                  RGDan59
                  RGDan59
                  RGDan59
                  @Nick-Carthew
                  Thanks. I see I can merge these “daily scenic rides” into my main route in the beginning or the end of my main route. I think it would be more helpful if I could choose where to insert them, as it would typically be somewhere between n the middle of the main route.
                  I wonder if it’s just better to keep these daily scenic routes as separate routes from the main route, then when I’m in that area, just ride the scenic routes.
                    RGDan59
                    RGDan59
                    RGDan59
                    @Nick-Carthew Hmm, I’ll look into this. Thanks!
                    • RGDan59 RGDan59
                      @Nick-Carthew
                      @RGDan59 said in Multiple routes, in a route:
                      @Nick-Carthew
                      I would suggest that you only use daily routes when navigating. There’s just too much information for your navigation device to deal with if you try and use the entire tour as one route.
                        @Nick-Carthew
                        RGDan59
                        RGDan59
                        RGDan59
                        @Nick-Carthew
                        That makes sense, thanks. I tried the split route feature but that just creates additional routes. So far, it still seems that I should keep daily fun rides separate from the main tour route.
                        RGDan59
                        RGDan59
                        • Map lock
                          tfdahazellgmail.com
                          tfdahazellgmail.com
                          98
                        • Beta abonnement
                          BMW1300GSA
                          BMW1300GSA
                          2.4k
                          Gerard van der Veer
                          Gerard van der Veer
                          526
                        • Uitnodiging
                          Hanza 0
                          Hanza 0
                          Hans Kremers
                          Hans Kremers
                        • SilverFox Controller C2
                          Hans Lamers
                          Hans Lamers
