  3. paved or gravel road.
suggestiongravel roadspaved roads
13 Posts 6 Posters 5.5k Views 2 Watching
  • C.A. Kielen
    C.A. Kielen
    C.A. Kielen
    Is it possible to show the difference between a paved and a gravel road? When you enjoy driving small roads abroad, it is often difficult to find out whether a road is paved or not.
    • flamingm0e
      flamingm0e
      flamingm0e
      To take it a step further, I would like a way to PREFER unpaved roads during planning process.
      C.A. Kielen MotoCon 2 Replies Last reply
      • C.A. Kielen C.A. Kielen
        @C-A-Kielen
        Gravel roads ar Grey on the Here map
        Robyn 1 Reply Last reply
          @C-A-Kielen
          Robyn
          Robyn
          Robyn
          @Hans-van-de-Ven-MRA-Master Is there a legend somewhere that we can reference?
          • Robyn Robyn
            @Robyn said in paved or gravel road.:
            Try this: https://www.openstreetmap.org/key
            Robyn MotoCon 2 Replies Last reply
            • Nick Carthew Nick Carthew moved this topic from [App-Beta] Suggestions and Discussions on
              Robyn
              Robyn
              Robyn
              @Nick-Carthew thank you!
                @Nick-Carthew, I would be surprised if the references for OSM are the same as for Here.
                  @Con-Hennekens Correct , but the original poster didn’t mention the Here map. You can check the type of road by using the OSM overlay.
                    @Nick-Carthew, Oh yes... I read that on a comment from Hans. I need to read better...
                    • flamingm0e flamingm0e
                      C.A. Kielen
                      C.A. Kielen
                      C.A. Kielen
                      @Matt-Flaming said in paved or gravel road.:
                      That would be even better
                      • C.A. Kielen
                        C.A. Kielen
                        C.A. Kielen
                        @Hans-van-de-Ven-MRA-Master said in paved or gravel road.:
                        @C-A-Kielen
                        When it is as simpel as that, I would not ask for it. Most of de Gray roads on the Here map are paved. But some are not. When there is streetview available you can check that, but the small roads often do not have streetview.
                        https://www.openstreetmap.org/key has options for all kinds of roads, but not for unpaved roads. So yes when there is an option that you can see which roads are unpaved during planning hat would be perfect.
                          If we are taking steps anyway, I would like a way to PREFER the green roads on the Michelin Layer (scenic roads).
                          C.A. Kielen 1 Reply Last reply
                            C.A. Kielen
                            C.A. Kielen
                            C.A. Kielen
                            @Con-Hennekens yes I use that too. But not all countrys have that. And for safety reasons I like to know if it is paved or not. The information is available because you can choose for using only paved roads.
                            C.A. Kielen
                            C.A. Kielen
                            flamingm0e
                            flamingm0e
                            Robyn
                            Robyn
                            • F014 WP Numbering illogical
                            • Map colours and side roads
                            • GPX POI Editor
                              RainerT
                              RainerT
                              Adrian Avram
                              Adrian Avram
                            • OSM Routing with MRA
