  3. paved or gravel road.
suggestiongravel roadspaved roads
13 Posts 6 Posters 4.8k Views 2 Watching
  • C.A. Kielen Offline
    C.A. Kielen Offline
    C.A. Kielen
    Is it possible to show the difference between a paved and a gravel road? When you enjoy driving small roads abroad, it is often difficult to find out whether a road is paved or not.
    • flamingm0e Offline
      flamingm0e Offline
      flamingm0e
      To take it a step further, I would like a way to PREFER unpaved roads during planning process.
      C.A. Kielen Con Hennekens 2 Replies Last reply
      • C.A. Kielen C.A. Kielen
        @C-A-Kielen
        Gravel roads ar Grey on the Here map
        Robyn 1 Reply Last reply
          @C-A-Kielen
          Robyn Offline
          Robyn Offline
          Robyn
          @Hans-van-de-Ven-MRA-Master Is there a legend somewhere that we can reference?
          • Robyn Robyn
            Nick Carthew Offline
            @Robyn said in paved or gravel road.:
            Try this: https://www.openstreetmap.org/key
            Robyn Con Hennekens 2 Replies Last reply
            • Nick Carthew Nick Carthew moved this topic from [Beta] Suggestions and Discussions on
              Robyn Offline
              Robyn Offline
              Robyn
              @Nick-Carthew thank you!
                @Nick-Carthew, I would be surprised if the references for OSM are the same as for Here.
                  @Con-Hennekens Correct , but the original poster didn’t mention the Here map. You can check the type of road by using the OSM overlay.
                    @Nick-Carthew, Oh yes... I read that on a comment from Hans. I need to read better...
                    • flamingm0e flamingm0e
                      C.A. Kielen Offline
                      C.A. Kielen Offline
                      C.A. Kielen
                      @Matt-Flaming said in paved or gravel road.:
                      That would be even better
                        C.A. Kielen Offline
                        C.A. Kielen
                        @Hans-van-de-Ven-MRA-Master said in paved or gravel road.:
                        @C-A-Kielen
                        When it is as simpel as that, I would not ask for it. Most of de Gray roads on the Here map are paved. But some are not. When there is streetview available you can check that, but the small roads often do not have streetview.
                        https://www.openstreetmap.org/key has options for all kinds of roads, but not for unpaved roads. So yes when there is an option that you can see which roads are unpaved during planning hat would be perfect.
                          If we are taking steps anyway, I would like a way to PREFER the green roads on the Michelin Layer (scenic roads).
                          C.A. Kielen 1 Reply Last reply
                            C.A. Kielen Offline
                            C.A. Kielen Offline
                            C.A. Kielen
                            @Con-Hennekens yes I use that too. But not all countrys have that. And for safety reasons I like to know if it is paved or not. The information is available because you can choose for using only paved roads.
                            C.A. Kielen
                            C.A. Kielen
                            flamingm0e
                            flamingm0e
                            Robyn
                            Robyn
                              Steve Jarrell
                              Steve Jarrell
                              8.4k
                              Albert Jan Gombert
                              Albert Jan Gombert
                              188
                              856
                            • Audio cuttet via Bluetooth
                              Haug
                              Haug
                              21.7k
