  3. POIs without routes
POIs without routes
4 Posts 2 Posters 714 Views
  • Colin Irvine
    Colin Irvine
    Colin Irvine
    I'd like to upload around 20 POIs, see how they're spread out, and then create a route from some of them. However, every time I load the POIs MRA turns them into a long complicated route. How can I stop it doing this?
    • Colin Irvine Colin Irvine
      @Colin-Irvine said in POIs without routes:
      When you choose to upload POIs make sure that you use the POI tab.
      When they upload they will go to your POI library. Tick the box to see them on the map and then add route points to navigate between them. You will need to click on each POI that you want to add to the route.
      • Colin Irvine
        Colin Irvine
        Colin Irvine
        Thanks, Nick. I should have spotted that. One last question - is there a way to load the POIs other than when zoomed in close?
          @Colin-Irvine No, not at the moment.
          Colin Irvine
          Colin Irvine
            Bouke Ent
            Bouke Ent
          • test Myroute APP
            1.9k
            Jörg Neudert
            Jörg Neudert
            686
          • How to plan correctly
            Christian Feurstein
            Christian Feurstein
            528
          • F001 POIs Adding from selection is not possible
            Hubert Thori
            Hubert Thori
            8.1k
            Mzokk
            Mzokk
