  4. Unable to stop navigation
32 Posts 8 Posters 4.6k Views 4 Watching
  • Peter Zehentreiterundefined Peter Zehentreiter
    @Herman-Veldhuizen How often do you press stop because you find it annoying?
    Con has already mentioned all the advantages. If it bothers you, you can let the navigation run during a break, and the double confirmation at the end of the route shouldn't be considered annoying.
    Referring to other apps that do things differently... I think it's good that there are different apps that work in different ways and have different features, so everyone can choose the app that suits them best.
    Herman Veldhuizenundefined Online
    Herman Veldhuizen
    @Peter-Zehentreiter Well I never felt the need to pause the navigation. So stop (end) is the only thing I needed so far. I use it to e.g. restart a navigation with different settings or to select another route to navigate.
    • Herman Veldhuizenundefined Herman Veldhuizen
      Con Hennekensundefined Online
      #22
      @Herman-Veldhuizen, many people did feel that need and explicitly asked for this feature. Personally, I usually just force close the app, by a swipe up.
      Herman Veldhuizenundefined 1 Reply Last reply
        Herman Veldhuizen
        @Con-Hennekens I am not asking to take away the pause but to reduce the number of clicks.
          @Herman-Veldhuizen, you do not need to do any extra click, you can leave that resume box untouched and just enter the routes menu to select another route.
            Herman Veldhuizen
            @Con-Hennekens yes but its still confusing as the dialog is still there after having selected another route. The dialog hides the opening page of the new route. At least on my android phone.
            • Nick Carthewundefined Online
              @Herman-Veldhuizen You seem to be making a very simple process incredibly complicated.
              You decide to stop somewhere and tap the 3 dots to open the navigation menu, you tap Stop navigation and then you are asked to confirm this by tapping a large Confirm button. The confirm button is there to safeguard any wrong taps that could be made when wearing gloves. The app is now in a paused state, you can swipe up and close the app if you want to. You can now watch YouTube videos, play a game of solitaire on your phone and when you’re ready to continue your journey, you open the app and the screen shows you a choice - Resume navigation - you can tap No or Navigate. What part of this simple process do you want to eliminate?
              • Nick Carthewundefined Nick Carthew
                Herman Veldhuizen
                #27
                @Nick-Carthew
                Beeeline does it the other way around: Resume dialog first, confirm second. Still the same amount of clicks to end a navigation (one less because the stop is on the main window instead of behind the ...) but one click less when you want to pause the navigation.
                I find it less annoying.
                https://drive.google.com/file/d/1erEEZwpurqkWfC-ZN-xj5qj8hiqrlbbq/view?usp=drivesdk
                in the video i show the resume first (play) followed by the end.
                • Guzzistundefined Guzzist
                  Since Version 5.x of MyRouteApp Navigation Next, I have been having difficulty ending navigation:
                  If I'm going to stop a navigation, there comes a first popup with question: "Stop navigation" with button "comfirm". This is in top area of the screen, and I can press button "confirm" also with gloves.
                  After confirming, the main screen appears, with a second popup question: "Resume navigation?" with buttons "no" and "navigate".
                  • Why question twice?
                  • Regardless, of whether you have used full-screen moder in settings, or not - the second qestion "Resume navigation" with buttons will be covered by device bottom menue:
                  Check with Samsung Galaxy Tab S8 (Android 16) in landscape format:
                  Check with DMD T865-X (Android 14) in landscape format:
                  For both devices, if they are used in portrait format - ther is no issue:
                  Please move question boxes up, so, the device bottom menue will not cover it, and users can hit the buttons securely, also with gloves.
                  @Guzzist The layout issue as this original topic is about will be fixed in the quick 5.0.4 update expected next week 🙂
                    @Nick-Carthew
                    @Herman-Veldhuizen Thank you, I am grateful to you for sharing your video but I am also aware that each navigation device has it's own method of carrying out similar procedures and I find nothing wrong or over complicated or confusing with the way that MRA Navigation Next choses to pause, resume or stop a route.
                      Herman Veldhuizen
                      @Nick-Carthew thats fine but i dont think that one can argue with the fact that a click less is a good thing in general.
                        @Herman-Veldhuizen said in Unable to stop navigation:
                        I have enough time for an extra tap 😉
                        • Corjan Meijerinkundefined Offline
                          Please stop the off topic discussion - as I'm processing the feedback of the original topic I want to keep the thread open but the discussion is not about the feature (which I'm happy about and won't change any time soon)
                          Marinus van Deudekomundefined
                          Herman Veldhuizen
                          Jörgenundefined
                          Guzzistundefined
                          • Need to adjust Time based on speed limits.
                            Herman Veldhuizen
                          • Account blocking issue
                            b0hd1undefined
                            b0hd1
                          • Update 5.2 - Persistent Map Items
                            Lluis Arasanzundefined
                          • Tracking
                          • Probleem met gedeelde route
                            nomkoundefined
                            nomko
                          • Waypoint verplaatsen uit zichzelf.
                            Ruurt Visserundefined
                            Ruurt Visser
                            595
                          • MRA Routeplanner Favorieten Permanent op kaart?
                          • MRA V5.2, Navigation alters the route
