  4. I don't need AA to run the app on a phone, right?
17 Posts 7 Posters 3.3k Views 3 Watching
  • Al Cohen
    Al Cohen
    Al Cohen
    I've searched for an answer to my question inthe Forums with no luck - sorry if this has been discussed before...
    I'm in the 2 week trial period for the MRA Navigation Next app. I created a test route in the web RoutePlanner, with renamed Shape and Via points, and everything worked fine in the MRA app on my Samsung S24 phone. I concurrently tested using Android Auto in my car, and while general functionality was fine, the glaring difference was AA did not show my renamed waypoint names the way my phone did. I rename most waypoints, so this feature is critical for me. So...
    I currently have a very old Garmin nuvi that I use the web Connector to export my gpx 1.1 routes to (and it shows my waypoint names). I like the idea of replacing the nuvi with a 6" rugged phone and not having to export/import to a GPS anymore. I see ALOT of discussion regarding AA/Carplay. I understand using that if your bike has this capability, but I would think the vast majority of motorcycles on the road are like my Harley Sport Glide and do not have that built in.
    In my situation, I'd just mount the phone, would not need a SIMM card, and run the MRA Nav app in offline mode after downloading the maps, right? Or I could enable a hotspot on my Samsung S24 and run online, right? Either way, I never have to mess with AA, right? I've used Tyre and myroute-app for close to 10 yrs, but I'm new to non-GPS navigation, so I appreciate the feedback and tips.
    Brian McG 1 Reply Last reply
    • Al Cohen Al Cohen
      @Al-Cohen sounds like you have it pretty got it all sussed right
      yes, the link up to AA does have quite a few kinks & missing detail
      yes, you can run MRA on a stand alone phone without anything to do with AA or without a sim card / network
      that is exactly how I run mine
      yes, you can hook up to your hot spot, I sometimes do but normally I just connect to the hotel Wifi before the days trip if i need to update / sync any routes
      BlackView BV7100, Android 12
      • Con Hennekens
        New bikes (and cars for sure) more often offer AA/CP functionality each year. My honest opinion is that for in my car (usually no scenic routes) that is just fine, but for on my bike (usually scenic routes) I consider it too complex and without too many of the operational elements we get in the full fledged app.
        An Android phone with military specs can be had really cheap nowadays and I consider that to be preferred for many years already. The app can function completely offline if you want, except of course for the syncing of routes. Like you say home or hotel wifi, and hotspots if necessary, are perfectly fine.
        • Al Cohen
          Al Cohen
          Al Cohen
          Thanks guys. Since you've been so helpful, here's a related question πŸ™‚
          I plan to get a 2nd phone for Nav use and run it offline with downloaded maps, and synched routes before starting the day. When you select a route from the library there are Navigate, Edit and Download buttons. I assume I need to Download the day's route as well or I'd lose navigation as soon as I lost wifi signal, right?
          Nick Carthew Con Hennekens Peter Zehentreiter 3 Replies Last reply
          • Al Cohen Al Cohen
            @Al-Cohen said in I don't need AA to run the app on a phone, right?:
            No, that is why you sync all routes. Syncing the routes makes them available for offline navigation. Just open your route and tap Navigate.
            • Al Cohen Al Cohen
              @Al-Cohen, Do what @Nick-Carthew suggests... Open the routes menu, tap the 3-dot menu top right en enable "Sync all my routes". You never need to look again! Just open the menu once before leaving home or hotel. The download functions are mainly there to enable transfer of routes to units like Zumo's and Riders.
              If you have not chosen a second phone yet, check out the Motorola Edge 50 Neo. Do buy a bumpercase along with it though. That's the one I would by at the moment.
              • Al Cohen Al Cohen
                @Al-Cohen @Con-Hennekens
                I have a Motorola Edge 40 and was very happy with Android 14.
                Since updating to Android 15, the phone is no longer usable for me.
                The Bluetooth connection to the Silverfox controller has to be reset every day.
                Also, since Android 15, the phone's start menu no longer allows apps to be arranged in landscape format.
                So if you decide to buy a Motorola phone, I would check beforehand whether it meets your requirements.
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                Con Hennekens Marinus van Deudekom 2 Replies Last reply
                  @Peter-Zehentreiter said in I don't need AA to run the app on a phone, right?:
                  That's good advice for any phone of course. But I do not recognize the issues you describe from my Thinkphone with Android 15. It does landscape just fine, also the Android main screen. And my Silverfox connects immediately anytime.
                  Dave J 0 1 Reply Last reply
                    @Con-Hennekens I have a Google Pixel 6 Pro and the Home Screen landscape view has been removed with Android 16. You still have landscape in those apps that enable landscape but not the Home Scren showing your apps.
                    More info from users on Reddit. One of the reasons I had the phone was for the Home Screen Autozoom rotate to landscape.
                    Ducati Multistrada V4 Rally
                    iPhone 18 Pro
                    CHIGEE AIO-6 LTE
                    • Marinus van Deudekom
                      In my Samsung S24FE with Android 16 landscape mode is possible on all screens
                        If your SilverFox has to be reset everyday I would advise you to disconnect it from your device. Then connect it again. If the problem stays update the software of the SilverFox
                        • Dave J 0 Dave J 0
                          @Dave-J-0, yeah, I just checked my Pixel 8 Pro, and I see what you mean indeed. I have no idea why google keeps making people angry with unthinkable changes like this. However, exactly for my nav-phone, I think this is pretty ideal, since I exclusively use it for Navigation in landscape πŸ˜‰
                          Dave J 0 Peter Zehentreiter 2 Replies Last reply
                            @Con-Hennekens As you say, it is what it is but I do miss the Autorotate. Like you though, my Pixel 6 Pro is just used for navigation in landscape.
                            iPhone 18 Pro
                            CHIGEE AIO-6 LTE
                              @Marinus-van-Deudekom All already done what you suggested.
                              Problem with the Motorola Edge 40 ( Android15) is still existing.(Android 14 was running without any problem)
                              Meanwhile I use a second Pixel 9 which works just perfect!
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Sena SLR 3
                              Sena 50 R
                                @Con-Hennekens Since Android 15 the Edge 40 doesn't even have a switch to change the home screen to landscape mode.
                                With the Pixel 9, I can at least decide whether I want to switch to landscape mode permanently.
                                With the Edge 40, this option has completely disappeared. However, I can still run apps in landscape mode.
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                  @Peter-Zehentreiter, a possible solution would be the use of Nova Launcher. I used that as an alternative launcher (main screen) on some of my previous phones and it works quite well.
                                    @Con-Hennekens Thank you for this hint.
                                    Maybe I'll give it a try.
                                    I have meanwhile arranged the necessary Navigation apps on the screen for an easy access.
                                    But as mentioned before I using now a Pixel 9 in connection with a Wunderlich USB Ladebox and Quad lock, which is just perfect for my needs.
                                    The Edge 40 will be used just in offline mode.
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                    Al Cohen
                                    Al Cohen
                                    • Live tracking
                                    • screen
                                      208
                                    • Vraagje over deze route en complimenten voor de nieuwe versie. πŸ‘
                                      PeterKerkhof
                                      PeterKerkhof
                                    • Overlapping routes
                                    • Rondrit generator ervaring
                                      AWDC LAO
                                      AWDC LAO
