  4. Map "spinning" when standing still
110 Posts 33 Posters 50.0k Views 10 Watching
  • peha peha
    The thread (at least how I meant it) is about the spinning when at a standstill; for me, there is no problem while moving. Unfortunately, the difficulties also occur on my phone (Samsung S22 Ultra) alone, without any Android Auto device involved, and they keep occurring with 5.02 as well. It happens at practically every stop, and almost every time the map then turns 180 degrees (facing the direction from where I came), causing the navigation to recalculate. Something must have changed compared to earlier versions-be it the app, the phone, or hardware conditions-because I did not have the problem this massively in the past. It drastically reduces the usefulness of the app, and it is not good news that seemingly not much can be done to solve this. 🙁 I do, however, appreciate the attempts to fix it, and I am hopeful that a new solution can be found and designed over time. I like the app a lot; it's been my everyday navigation app (and especially now, with free drive, even more so)-I believe in the team's ability to eventually find a fix for the phenomenon. 🙂🚀
    @peha said in Map "spinning" when standing still:
    That in itself already is a strange phenomenon, since at speeds under a certain level, no recalculation should be triggered at all (because it is considered a stand still).
    • peha peha
      @peha For me, the problem already existed with previous versions.
        @Con-Hennekens yesterday I noticed that in both Freedrive and A2B route when I came to a complete stop the position marker turend. Most of the time 90degrees Right. It did not recalculante. I’ve never s’en it before. I was out with just my phone
          Same for me (with the latest update!)
          Had no problem last time on my bike but yesterday as well on my phone as on the AA screen in my car!
          • Nick Watts
            Nick Watts
            Nick Watts
            +1 same issue - every time I stop (at traffic lights, etc.) the map spins 180 degrees as if I'm facing the other way. Once I'm underway again it spins back and the navigation continues correctly.
            Samsung S24 Ultra, fully patched and up to date.
            No such issues with Google Maps or other nav programs.
            • Albert van den Elsen
              wrote on last edited by Albert van den Elsen
              #66
              In my opinion this has nothing to do with MRA or other nav tooling.
              I found this article.
              Sorry but I cant test it, perhaps there is a solution for you in it.
              If you don't try, you'll never know. Fingers crossed. Good luck.
              The Samsung Galaxy S24 Ultra is a fantastic device, but precisely because it is so large and packed with sensors, it can sometimes be extra sensitive to magnetic interference.
              Here are some specific steps and tips for your S24 Ultra to stop that "spinning":
              1. Calibrating via the hidden menu
                You can test and reset your Samsung's sensors directly:
              Open the Phone app and dial: #0#
              Tap the Sensor tile.
              Look for Magnetic Sensor. You will see a small circle with a line (the compass).
              If the line is red and shows a "0", it is not calibrated.
              Move your phone in a figure-8 motion until the line turns blue and a "3" appears. This indicates it is perfectly calibrated.
              Tap the 'Back' button a few times to exit the menu.
              1. Check your case (MagSafe accessories?)
                The S24 Ultra is often used with cases that contain magnets (such as MagSafe-compatible rings or wallet flaps).
              The culprit: Magnets in your case directly interfere with your S24 Ultra’s magnetometer.
              Test it: Take your phone out of the case and see if the map in Google Maps stays still. If it works correctly without the case, you’ll know the magnets in the case are causing the interference.
              1. Google Maps "Live View" calibration
                Sometimes the magnetic field in a city (due to trams, pipes, or reinforced concrete) is too unstable for a compass.
              In Google Maps, tap the blue dot (your location).
              Choose the option Calibrate with Live View.
              Use your camera to scan the buildings and street signs around you. The S24 Ultra then uses image recognition to lock in your direction, which is much more stable than the compass.
              1. Specific S24 settings
                Ensure your phone's "assistance" features are enabled:
              Go to Settings > Location > Location Services.
              Make sure Google Location Accuracy is turned on.
              Also, turn on Wi-Fi scanning and Bluetooth scanning. This helps your phone determine your position based on nearby routers, which results in less "drift" than using GPS alone.
              Do you happen to have a case with a magnet or a card holder on the back of your S24 Ultra?
              iPhone 15,
              Garmin Zumo XT3
              Carpuride W702 Pro
              Sena 20S EVO headset
              Harley Davidson Road King M8
              • Vincent Curren
                Vincent Curren
                Vincent Curren
                I also have had the issue navigating with an older Kyocera E7110 on the phone screen without Android Auto. 180 degree turns, usually settling on the opposite way to the direction I was traveling. Functionally, it's mostly a problem for me on a roads I don't know just after I've made a turn and have to stop for traffic or a red light. Under those conditions, it's easy for me to get confused about whether I'm going in the right direction.
                • Christoph Wallwey
                  Christoph Wallwey
                  Christoph Wallwey
                  Same issue here on my iPhone Air. Managed to work around it with an automation in the shortcuts app.
                    I’ll definitely spend some more time! 🙂
                    peha
                    peha
                    peha
                    @Corjan-Meijerink Is there anything on the horizon, regarding potential updates, if/when a fix or workaround might be found? It seems, since the last update the app waits longer (i.e., there's a delay of several seconds) before the map spinning starts, but it's still there, unfortunately, and not a good experience, as already described ad nauseum in this thread. 😉 I understand there's no such thing as a definite date or promise of any kind, but may I ask if the problem is being investigated further - is this being worked on still? Thanks! 🙂
                    BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
                    VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
                    Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
                    • Hubert Thoring
                      #70
                      This post is deleted!
                      • Hubert Thoring
                        Had to delete the text because the translation welcome was wrong .. Sorry ✅
                        Will write it again later ..
                          I noticed the same on my tablet.
                          Hns_Brwr
                          Hns_Brwr
                          Hns_Brwr
                          @Jörgen said in Map "spinning" when standing still:
                          ik ook. Met de laatste versie. Helemaal draaierig wordt ik er van
                          • peha
                            peha
                            peha
                            @Corjan-Meijerink I'm bumping this; is this issue being actively worked on?
                            • Lluis Arasanz
                              I can say that is a little annoying when on an stop, it rotates 180 degrees and hides all route .
                              I’m trying to understand why and how… and my impression is about. Compass tries to to be on pointing north, or if not possible, gets northern street direction.
                              I’ll continue to look for a pattern, but sometimes I’ say bad words under my helmet.
                              Please take a look on it
                              Regards
                              • BMW F750GS
                                wrote on last edited by LE DIZES Freddy
                                #75
                                @Corjan-Meijerin hello Corjan what news about this problem merci
                                • Erdna
                                  Hi all,
                                  I can confirm this behaviour on Fossibot F101 Pro running Android 13 and Google Pixel 9 running Anroid 16. App is most recent Play Store version on both.
                                  Regards,
                                  André
                                  • TomOnTour
                                    TomOnTour
                                    TomOnTour
                                    Hi all,
                                    same here: I had the same issues the last 2 days, but sometimes verything works just fine. I haven‘t been able to find out what gibt trigger it. Remembering some technical details around GPS I know that it is sometimes pretty hard for GPS devices to identiofy the direction, when there is no moment. This would explosion, way it is getting in the right position and direction, as soon as you start moving again.
                                    Greetings
                                    Thomas
                                    • TomOnTour TomOnTour
                                      Hi all,
                                      Greetings
                                      Thomas
                                      @TomOnTour said in Map "spinning" when standing still:
                                      Hopefully my bike will NOT "explode" tomorrow when I'll open the bike season 2026
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Motorola Edge 40 "offline"
                                      Sena SLR 3
                                      Sena 50 R
                                      TomOnTour 1 Reply Last reply
                                        TomOnTour
                                        TomOnTour
                                        TomOnTour
                                        @Peter-Zehentreiter said in Map "spinning" when standing still:
                                        Aaargh, I hate the spelling changes 🙂
                                        My intention was th write "explain"
                                        Sorry, for scaring you a bit 🙂
                                        Greetings
                                        Thomas
                                          Greetings
                                          Thomas
                                          @TomOnTour Sure, I know that you wanted write " explain" instead of explosion.
                                          My comment was also intended as a joke.
                                          Regards
                                          Peter
                                          BMW R 1250 GS
                                          DMD-NOR7E 7"
                                          SPC Universal mount
                                          Sena SLR 3
                                          Sena 50 R
                                          • 4
                                          • 5
                                          • 6
                                          Paul Steinberg
                                          Paul Steinberg
                                          Bouke Ent
                                          Bouke Ent
                                          peha
                                          peha
                                          Herman Veldhuizen
                                          Herman Veldhuizen
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Bill Harrison
                                          Bill Harrison
                                          TomOnTour
                                          TomOnTour
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                          • MRA Studio export speed
                                          • Hiya from UK
                                            Russ Nattrass 1
                                            Russ Nattrass 1
                                          • geeft routepunt niet weer
