  4. Map "spinning" when standing still
110 Posts 33 Posters 52.7k Views 10 Watching
  • Vincent Curren
    Vincent Curren
    Vincent Curren
    I also have had the issue navigating with an older Kyocera E7110 on the phone screen without Android Auto. 180 degree turns, usually settling on the opposite way to the direction I was traveling. Functionally, it's mostly a problem for me on a roads I don't know just after I've made a turn and have to stop for traffic or a red light. Under those conditions, it's easy for me to get confused about whether I'm going in the right direction.
    • Christoph Wallwey
      Christoph Wallwey
      Christoph Wallwey
      Same issue here on my iPhone Air. Managed to work around it with an automation in the shortcuts app.
        I’ll definitely spend some more time! 🙂
        peha
        peha
        peha
        @Corjan-Meijerink Is there anything on the horizon, regarding potential updates, if/when a fix or workaround might be found? It seems, since the last update the app waits longer (i.e., there's a delay of several seconds) before the map spinning starts, but it's still there, unfortunately, and not a good experience, as already described ad nauseum in this thread. 😉 I understand there's no such thing as a definite date or promise of any kind, but may I ask if the problem is being investigated further - is this being worked on still? Thanks! 🙂
        BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
        VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
        Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
        • Hubert Thoring
          #70
          This post is deleted!
          • Hubert Thoring
            Had to delete the text because the translation welcome was wrong .. Sorry ✅
            Will write it again later ..
            • Jörgen Jörgen
              I noticed the same on my tablet.
              Hns_Brwr
              Hns_Brwr
              Hns_Brwr
              @Jörgen said in Map "spinning" when standing still:
              ik ook. Met de laatste versie. Helemaal draaierig wordt ik er van
              • peha
                peha
                peha
                @Corjan-Meijerink I'm bumping this; is this issue being actively worked on?
                • Lluis Arasanz
                  I can say that is a little annoying when on an stop, it rotates 180 degrees and hides all route .
                  I’m trying to understand why and how… and my impression is about. Compass tries to to be on pointing north, or if not possible, gets northern street direction.
                  I’ll continue to look for a pattern, but sometimes I’ say bad words under my helmet.
                  Please take a look on it
                  • BMW F750GS
                    LE DIZES Freddy
                    LE DIZES Freddy
                    LE DIZES Freddy
                    wrote on last edited by LE DIZES Freddy
                    #75
                    @Corjan-Meijerin hello Corjan what news about this problem merci
                    • Erdna
                      Erdna
                      Erdna
                      Hi all,
                      I can confirm this behaviour on Fossibot F101 Pro running Android 13 and Google Pixel 9 running Anroid 16. App is most recent Play Store version on both.
                      Regards,
                      André
                      • TomOnTour
                        TomOnTour
                        TomOnTour
                        Hi all,
                        same here: I had the same issues the last 2 days, but sometimes verything works just fine. I haven‘t been able to find out what gibt trigger it. Remembering some technical details around GPS I know that it is sometimes pretty hard for GPS devices to identiofy the direction, when there is no moment. This would explosion, way it is getting in the right position and direction, as soon as you start moving again.
                        Greetings
                        Thomas
                        MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
                        MRA Navigation Next (Lifetime Gold)
                        MRA Routeplanner NEXT beta (Lifetime early access)
                        • TomOnTour TomOnTour
                          Hi all,
                          Greetings
                          Thomas
                          @TomOnTour said in Map "spinning" when standing still:
                          Hopefully my bike will NOT "explode" tomorrow when I'll open the bike season 2026
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Motorola Edge 40 "offline"
                          Sena SLR 3
                          Sena 50 R
                          TomOnTour 1 Reply Last reply
                            TomOnTour
                            TomOnTour
                            TomOnTour
                            @Peter-Zehentreiter said in Map "spinning" when standing still:
                            Aaargh, I hate the spelling changes 🙂
                            My intention was th write "explain"
                            Sorry, for scaring you a bit 🙂
                            Greetings
                            Thomas
                              Greetings
                              Thomas
                              @TomOnTour Sure, I know that you wanted write " explain" instead of explosion.
                              My comment was also intended as a joke.
                              Peter
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Sena SLR 3
                              Sena 50 R
                              • Peter Zehentreiter
                                There are currently two of us travelling through Slovenia and Croatia...
                                My colleague uses MRA on an iPhone; I use Android.
                                At the moment, whenever we stop at a traffic light or a stop sign – whether in town or in the countryside – the map on both devices starts rotating while we’re stationary 🤬
                                Earlier, we had to turn around at a roadworks site... I wanted to zoom in to see how we could get round the roadworks... then, whilst searching for an alternative route, the map started rotating.
                                This is extremely annoying, and it’s also a hassle to search for a different route with the map upside down.
                                Please fix this bug as soon as possible.
                                Thanks
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                • Jörgen
                                  Read here:
                                  https://forum.myrouteapp.com/topic/10633/turning-of-the-screen-when-standing-stil/2?_=1775735018064
                                  Will be fixed soon.
                                  • Jörgen Jörgen
                                    Read here:
                                    Will be fixed soon.
                                    @Jörgen Thanks for the link to the other conversation which I have already read.
                                    I just wanted to keep this annoying issue in Corjan's mind.
                                    Slovenia is geil at this moment 😉. Wir are almost alone on the on most of the streets.
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                      The issue has been identified.
                                      Unfortunately the HERE SDK is the cause 😉
                                      They have fixed it in a recent update but that version contains another issue causing us definitely not to update just yet.
                                      Developers informed me that the blocking (other) issue is solved in their next update so hopefully it’s available soon 🙂
                                      peha 1 Reply Last reply
                                        peha
                                        peha
                                        peha
                                        @Corjan-Meijerink Is there any timeline or estimate for when the spinning issue might be resolved-one week, one month, or another six months? (The initial problem description in this thread dates back to November 2025.) I understand it's supposedly a third-party problem, but it's still very annoying, and the lack of transparent communication doesn't help. Could you please share some insight into what a realistic expectation might be for this to be fixed for end users? Thank you!
                                        • peha peha
                                          #86
                                          @peha After my last statement I would not say there is a lack of transparency 🙂
                                          I also replied in the other thread, no need to ask twice.
                                          Edit: no hard feeling, I understand the frustration and I really want it solved too ❤
                                          • 4
                                          • 5
                                          • 6
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          TomOnTour
                                          TomOnTour
                                          Albert van den Elsen
                                          Paul Steinberg
                                          Paul Steinberg
                                          peha
                                          peha
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
