Online map settings
HERE does support pedestrian and cycling mode. That is I think what you get when you "navigate" (walk) a foot or (cycle) a cycling route.
correct, but you cannot plan routes in NN
If I only use the app and only the Here maps (no "online" map), both for planning and navigation, I am not working cross platform. In that case I don't see a reason why editing should not be allowed.
Here is an example.
The first picture shows my walking route through a city. Perfectly ok and made by the app.
The second one shows the route with the travel mode car. But the only way to make the first is though the second : by using the travel car for editing. The route becomes a walking route by changing the travel mode to foot, after editing.
That’s interesting!
Have you signed up for the beta? When I start creating a new route with the app, there are no options for walking or cycling:
EDIT: got it - I have to create a route in car mode and after saving(!), I can reopen the route and switch to foot or cycle. A bit confusing, but it seems to work…
Not using beta. You can change the travel mode AFTER editing and saving the route. That will update the route as well. This is probably a loophole but it would be a pity if the app should not be used to edit a Here based walking or cycling route.
Yep - SAVING is the key.
And another bug: when car is assigned, I can edit the route, and if I change it to foot, I can edit the route as well.
However, after entering edit mode and returning (or leaving the preview page and coming back), I can't edit the route. I first have to change back to car and leave the preview page.So, all in all, it looks like editing a route in foot or cycle mode isn't intended, but because the route doesn't auto-save immediately after changing its mode, it's still possible.
To be honest, MRA (NEXT) is designed for cars and motorcycles—not for creating cycling or hiking routes. There are other applications, such as Strava and Komoot (to name just a few), that are specifically built for that target audience.
While MRA can certainly be used to create routes, it does not support the TCX or FIT file formats—the latter having effectively become the industry standard for cycling computers and sports watches.
Furthermore, I doubt they even want to compete in that space; platforms like Strava already have such a large, established user base and are so popular that a small business would never see a return on the time and effort required to challenge them.Yes, you can create cycling and hiking routes in MRA, but if you want to use them effectively on a sports watch or a cycling computer—such as a Garmin Edge or a Wahoo device—you are essentially tied to one of the aforementioned platforms or Garmin Connect.
I agree - competing with these hiking/cycling platforms is probably not one of MRA’s major goals.
On the other hand, MRA is actively promoting this as new or improved features for V6, and they even added specific online maps for these navigation modes, so they are clearly taking it seriously.
But anyway, if it's for hiker and cyclists, being able to create and edit routes with the app is mandatory - we don't carry laptops while out on the trails, right?
