  4. Online map settings
Online map settings
25 Posts 4 Posters 780 Views 2 Watching
  • Herman Veldhuizen
    wrote last edited by Herman Veldhuizen
    HERE does support pedestrian and cycling mode. That is I think what you get when you "navigate" (walk) a foot or (cycle) a cycling route.
    BertM 1 Reply Last reply
      #17
      correct, but you cannot plan routes in NN
      MartinW 1 Reply Last reply
      • BertM BertM
        MartinW
        MartinW
        MartinW
        @BertM [sagte](/post/89
        Exactly. Cross-platform editing still works only for routes with one of HERE’s standard travelling modes.
        • Herman Veldhuizen
          #19
          If I only use the app and only the Here maps (no "online" map), both for planning and navigation, I am not working cross platform. In that case I don't see a reason why editing should not be allowed.
          Here is an example.
          The first picture shows my walking route through a city. Perfectly ok and made by the app.
          The second one shows the route with the travel mode car. But the only way to make the first is though the second : by using the travel car for editing. The route becomes a walking route by changing the travel mode to foot, after editing.
          • MartinW
            MartinW
            MartinW
            wrote last edited by MartinW
            #20
            That’s interesting!
            Have you signed up for the beta? When I start creating a new route with the app, there are no options for walking or cycling:
            EDIT: got it - I have to create a route in car mode and after saving(!), I can reopen the route and switch to foot or cycle. A bit confusing, but it seems to work…
            • Herman Veldhuizen
              #21
              Not using beta. You can change the travel mode AFTER editing and saving the route. That will update the route as well. This is probably a loophole but it would be a pity if the app should not be used to edit a Here based walking or cycling route.
                MartinW
                MartinW
                MartinW
                #22
                @Herman-Veldhuizen
                Yep - SAVING is the key.
                • MartinW
                  MartinW
                  MartinW
                  #23
                  It's even more strange; I can change to foot or cycle on the overview/preview page, but not when in edit mode:
                  • MartinW
                    MartinW
                    MartinW
                    #24
                    And another bug: when car is assigned, I can edit the route, and if I change it to foot, I can edit the route as well.
                    However, after entering edit mode and returning (or leaving the preview page and coming back), I can't edit the route. I first have to change back to car and leave the preview page.
                    So, all in all, it looks like editing a route in foot or cycle mode isn't intended, but because the route doesn't auto-save immediately after changing its mode, it's still possible.
                    • BertM
                      #25
                      To be honest, MRA (NEXT) is designed for cars and motorcycles—not for creating cycling or hiking routes. There are other applications, such as Strava and Komoot (to name just a few), that are specifically built for that target audience.
                      While MRA can certainly be used to create routes, it does not support the TCX or FIT file formats—the latter having effectively become the industry standard for cycling computers and sports watches.
                      Furthermore, I doubt they even want to compete in that space; platforms like Strava already have such a large, established user base and are so popular that a small business would never see a return on the time and effort required to challenge them.
                      Yes, you can create cycling and hiking routes in MRA, but if you want to use them effectively on a sports watch or a cycling computer—such as a Garmin Edge or a Wahoo device—you are essentially tied to one of the aforementioned platforms or Garmin Connect.
                      MartinW
                      MartinW
                      • Online map settings
                        780
                        Axel Lange
                        Axel Lange
                      • In het kort......
                      • View a route from the previous planner
                      • Gesproken aanwijzingen per instructie erg laat
