Online map settings
Das mp4 zeigt einen fly-through - mich interessiert hauptsächlich, wie die echte Navigation aussieht. Gibt es TBT Anweisungen oder geht das nur als off-road Navigation?
@MartinW Dazu müsste ich jetzt eine Route abfahren... ist mir persönlich aber heute zu kalt .
Ich hab noch ein kurzes Video gemacht (ist im vorherigen Ordner abgelegt) wo Du sehen kannst das ich die Route gestartet habe und dann die weiteren Optionen aufgemacht, zumindest dort werden Sprachansagen gemäß der Einstellungen angezeigt und die Routenführung zeigt die Entfernung bis zum Ziel an und warnt Dich wenn Du die Route verlassen solltest.
Yes, some kind of auto-assignment of a map type according to the route type.
But how does it work?
Not while navigating:
And if I create a new route, I can't select bicycle as the route type:
Could you please provide more details on how to use it?
Not while navigating:And if I create a new route, I can't select bicycle as the route type:
No, creating a route in the app is only is possible on the Here map, and does not support bicycle, only car and motorbike
If you have a route from your libary made for bicyle it will open the selected map. If you have outdoor selected for hiking it selects this map. It will then use this map for navigating the route
Thanks!
That's exactly what I expected: I can create hiking/cycling routes in OSM using the new beta planner and navigate them with NN V6, where the map automatically switches according to the settings mentioned above. I get basic info on the remaining distance while navigating (”off-road mode”), but no TBTs.
Since NN V6 is limited to the HERE routing engine, that's likely the best we can get.
@martinw
Your understanding is correct. I must admit that i struggled to understand the above also, but @nick-carthew helped me on that
I hope the new planner has some improvements for cycling. (I do not participate in the Beta).I do not use NN on the bicycle, but use a Garmin Edge. I like the web planner and use that one to create my cycling routes, the GPX of the track I then convert to a Garmin TCX or FIT file with turn alerts with a little tool I made.
HERE does support pedestrian and cycling mode. That is I think what you get when you "navigate" (walk) a foot or (cycle) a cycling route.
correct, but you cannot plan routes in NN
If I only use the app and only the Here maps (no "online" map), both for planning and navigation, I am not working cross platform. In that case I don't see a reason why editing should not be allowed.
Here is an example.
The first picture shows my walking route through a city. Perfectly ok and made by the app.
The second one shows the route with the travel mode car. But the only way to make the first is though the second : by using the travel car for editing. The route becomes a walking route by changing the travel mode to foot, after editing.
Not using beta. You can change the travel mode AFTER editing and saving the route. That will update the route as well.
