Navigating on NEX
First, I'd like to congratulate the developers on their excellent work.
I'd like to suggest that in the NEX app, I'm navigating with an 8" Samsung A5 tablet. As you can see in the photo, the upper (blue) box indicating the next maneuver is excessively large for this purpose, as is the lower (white) box showing the remaining time. I think they significantly reduce the visibility of the route map and consequently make it appear smaller. Do you think these boxes could be reduced in size? Thank you for your attention and congratulations on MRA! -
Thanks for the kind words!
I can confirm this will be fixed in the upcoming update
I'd like to suggest that in the NEX app, I'm navigating with an 8" Samsung A5 tablet. As you can see in the photo, the upper (blue) box indicating the next maneuver is excessively large for this purpose, as is the lower (white) box showing the remaining time. I think they significantly reduce the visibility of the route map and consequently make it appear smaller. Do you think these boxes could be reduced in size? Thank you for your attention and congratulations on MRA!@Lluís-Casals Hi Lluis, on Sunday we noticed the same "problem" on Xavi's tablet. We fixed it by changing a couple of settings—specifically font size and resolution—in the "display" section on the tablet itself. Give that a try and see if it works for you!
Seeks: "tamaño y estilo de fuente" and "zoom de pantalla":
Regards!
Thanks Corjan.
Thanks Oscar, I'll try it.
Cheers.
That's right, Oscar, it's not in "font size" and "display size".
It's in "screen zoom".
Solved!!!!!
Regards -
Solved!!!!!
RegardsThat's right, Oscar, it's not in "font size" and "display size".
Solved!!!!!
Regards...hmmm - have the same issue - but at my device, there is no option "screen zoom" available
Solved!!!!!
@Guzzist must be something in your settings because on my 250 km tour from yesterday I had zero problems with the T865X
Solved!!!!!
