  4. No tracklog on Android phone
10 Posts 3 Posters 178 Views 1 Watching
  • Reinhard Grossmann h 0
    wrote last edited by
    Hello!
    I‘ve been using MRA for a while to planning of routes. The GPX files were then loaded into Garmin Zumo XT (I hadn‘t been pleased with that device), which I sold and instead got me a Gigaset GX6 Smartphone with Android operating system, and installed the Myroute-app.
    To my great chagrin I could never get a tracklog when navigating using that app. I tried different settings, de- and re-installed the app. I did sent my complaint to the developers of Myroute and since we’re trying to find a solution. Thank you, dear Jarnick!
    However, until to date we’re not having any idea as to how to fix the problem. Thus I’m posting this request asking whether anybody else would have or have had a similar problem of being unable to record and to save a tracklog on Android smartphones.
    Left hand to greeting!
    Reinhard
    Nick Carthew Con Hennekens 2 Replies Last reply
    • Reinhard Grossmann h 0 Reinhard Grossmann h 0
      Hello!
      Reinhard
      @Reinhard-Grossmann-h-0 Do you see a green spot in the ETA box after you start navigating? This indicates that you are tracking your route. And have you selected to Show tracklog in Navigation settings > Screen layout > Lines? This will show a yellow line when you are tracking.
        @nick-carthew
        Thank you.
        No, I never saw that green dot, which puzzles me ever from the beginning.
        Yes, I’ve switched on “Lines”
          @nick-carthew
          Thank you.
          @Reinhard-Grossmann-h-0 Do you have location services set to allow all the time?
          And do you have Accuracy set to use precise location?
          Reinhard Grossmann h 0 2 Replies Last reply
            To both questions the answers are YES, I did
              @Nick-Carthew
              The answers to both of your quwstions are YES, I did.
                @Nick-Carthew
                @Reinhard-Grossmann-h-0 I suspect the problem lies within your phone then.
                  Hello!
                  Reinhard
                  @Reinhard-Grossmann-h-0, What exactly happens when you try to start a tracklog, by manually pressing the tracklog button?
                  I have some experience with a finicky tracklog start, but I thought that was limited to some of the beta versions. The tracklog would not start (not automatically nor manually) and the button would refuse to turn green. After a forced close (not the swipe method, but from the apps section in your Android system settings) it would work once, but then the problem came back.
                  If you recognize what I describe, I am pretty sure it will be solved in the upcoming V6 version of the app. And if you do not recognize this, it will probably be fixed in V6 too 😉
                    @con-hennekens
                    @nick-carthew
                    Thank you all for your considerations. Today it was for the first time that the App recorded the track. Again I had erased and then re-installed the App, downloaded some maps, and then I turned practically everything within the settings “ON”, only switched off “Data on memory card” and disabled “Offline Navigation“. So let us see whether or not today’s experience was just a “one-hit wonder”
                    Left hand greeting!
                    Reinhard
                      @con-hennekens
                      Hi Con,
                      I really like your statement regarding the link between handle bars and saddle 🙂
                      May I eventually quote it?
                      Left hand greeting out of the gorgeous South of Germany/North of Bavaria which is named Franconia!
                      Reinhard
                        3.5k
                        191
                      • Overlay Routes like the App does and waypoints without routes
                        Rob Kelley
                        Rob Kelley
                      • Route Breakdown
                        Scarecrow
                        Scarecrow
                      • Vergrendel scherm zet alles op z'n kop
                        Stanisław
                        Stanisław
                      • MRA 6.0.0 - 515 Carplay folder twice
