  4. Drive restriction for vehicle
33 Posts 7 Posters 326 Views 4 Watching
  • Travellexxie Travellexxie
    Another tip: set the weight of your camper 1kg under the maximum weight: not 4500 but 4499. The limitations are "from" a certain weight and not "up to" a certain weight.
    Robineke
    Robineke
    Robineke
    @Travellexxie I am missing your point. The restriction if for vehicle 3,5t. This means no entry for 3,5 ton and higher.
    What will differ when I change 4500 into 4499?
    Rob Verhoeff Travellexxie 2 Replies Last reply
    • Robineke Robineke
      @Robineke I think camper-mode has broken in one way or the other as @travellexxie mentioned...
      • Robineke Robineke
        @Robineke I don't think it is suitable for you (are there 4.500 limitations?idk), but here is an example: if your campers weight is max 4.500 and the limitation is 4.500, it will give you no access to these roads. You are only allowed for roads >4.500. That 1kg raise your limitation to the next step. Therefore, in your account, fill in 1kg less.
        MRA Lifetime Gold
        Robineke 1 Reply Last reply
          Robineke
          Robineke
          Robineke
          @Travellexxie I got your point, I think. My camper weight is 4500kg but the road is limited to 3500kg.
          It means that my weight is far higher then allowed so MRA should take that in account.
          And that is not what it does only at the latest moment of entry, when I see the sign, it mentions "restricted road".
          Unfortunately it does not provide another road and still guids me over the road which is limited to max 3500kg.
          • Robineke Robineke
            @Robineke like I wrote before, something must be broken. In that case you could better use the other profile.
            MRA Lifetime Gold
              I've fixed an issue regarding this routing.
              That works immediately on the website.
              For the app itself it will be included in the big v6 update.
                @Corjan-Meijerink it seems fixed, but can you also bring de signs back? I see them in the truck profile, not in the camperprofile
                MRA Lifetime Gold
                Robineke Corjan Meijerink 2 Replies Last reply
                  Robineke
                  Robineke
                  Robineke
                  @Travellexxie In my routelab I see the traffic sign limitation in truck AND in camper mode.
                  Fro me this is excellent. Thanks to all for their input and (coming) update.
                    @Travellexxie Nothing changed regarding that
                    • Travellexxie
                      That's funny, I don't. And the most funny part is (I raised my camper to 4500kg), that in the truck mode, the route still goes over the <3500 road. In Camper mode it is OK, but the sings aren't there.
                      Camper mode
                      Truck mode
                      MRA Lifetime Gold
                        Camper mode
                        Truck mode
                        @Travellexxie, For truck mode automatically the logistics layer gets activated, for camper mode it does not, because many campers don't need that. Just enable the logistics layer 😉
                          @Con-Hennekens they were there before and they should be there, how should I else know over what roads I am allowed to travel 🤷
                          MRA Lifetime Gold
                            @Travellexxie Maybe you were already using the HERE Logistics overlay map, the overlay map is remembered from your last route.
                              @Nick-Carthew no I didn't, I have used the camperprofile plenty of times during my 3 months travel through Spain and Portugal, The "weight-indicator" was there when I started this profile.
                              MRA Lifetime Gold
                                @Nick-Carthew I opened the navigation app and also there these weight and length indicators are gone. So that would indicate that the camperprofile does not show these indicators, whether I use the web planner or the navigation app. But surprise surprise I made some screenshots during my trip. These were taken in the south of Portugal, with the camper profile on, on the 12th and 12th of April. In no way is there a layer with these weight and length indicators. So how would you explain that?
                                MRA Lifetime Gold
                                  @Travellexxie Maybe you should be asking Corjan, I was merely making a suggestion trying to help you find a solution.
                                  • HABVEN aka MrMRA
                                    Shortly after the introduction of the camper profile, I conducted a training session for the Camper Club Netherlands; at that time, the signs on the map became visible as soon as you selected the camper profile, meaning the logistics map layer was automatically loaded—just as it was with the truck profile.
                                      @Hans-van-de-Ven-MR.MRA thank you for the confirmation!
                                      MRA Lifetime Gold
                                        Camper profile does not open the logistics layer since 2024-09-25.
                                        If we're still talking about the website.
                                          Robineke
                                          Robineke
                                          Robineke
                                          @Travellexxie I can see your printscreens and both are in here-logistic mode as the maps are, except for signs, identical.
                                          As mentioned I have in both modes weight limitation signs. Funny, but not nice, you do not have it.
                                          I do not know how to resolve this except for deleting and new downloading of the app.
                                          Robineke
                                          Robineke
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
                                            162
