  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 9.8k Views 9 Watching
  • LennyO
    Hello, all!
    I think I have seen this discussed before, but can not find it...
    Anyway, the North-South-East-West Red segment on the elevation circle is not working properly and therefore is very confusing.
    Has this been looked into and if yes, what is the latest on that?
    Thanks!
    • RetiredWingMan
      The red segment shows the direction to north.
      LennyO 1 Reply Last reply
        @RetiredWingMan
        Well.... it should ! But..... look at this pictures. I am standing in the same spot facing due South. My Pap is oriented North.
          We aren't a compass app.
          If you stand still be don't do much effort 🙂
          • superg
            It's given you the direction when you are moving .
              Just look at the pictures in this thread made by Jörgen!
                @white.mouse Sorry, what pictures in which thread?
                • Jim Allen
                  Jim Allen
                  Jim Allen
                  When one navigates with the app one sees the altitude with a compass indication around the circle. These red segment
                  indicators should show the direction that one is traveling In fact the indicator correctly indicates north and south but east and west is backwards. While traveling east the red bar indicator shows west. In other words with I travel west the red indicator should be on the left. That is not the case now. I am using an iPhone 14 pro max with revision 5.2.0 - 473.
                    sorry,
                    Here's the link
                    https://forum.myrouteapp.com/topic/11064/compass-is-not-working-properly/8?_=1785773867949
                    or
                    https://forum.myrouteapp.com/post/81307
                    • LennyO
                      Ok, thanks to all!
                      I guess I needed a mental adjustment to understand that the red segment just says where the North is in relation to the direction I am traveling (to my nose... )
                      That said, please confirm that the following pictures show the expected behavior of the Red segment. My map is oriented NORTH, so you can easily see in which direction I am moving. Thank you!
                      IMG_0005.jpg IMG_0007.jpg IMG_0010.jpg IMG_0012.jpg IMG_0014.jpg IMG_0016.jpg
                      • Marinus van Deudekom
                        To me that makes no sense at all. But then again I never use North up.
                        Something tells me in top of that it only works when using the dynamic camera view but I'm nooit shure
                          @Marinus-van-Deudekom The behavior of the Red segment is the same in every mode. I just verrified it on a ride this morning. In the Dynamic mode the Blue Arrow in the bottom right acts as a compass too, and it coinsides with the Red segment behavior.
                            Agree that it looks strange in the north up view.
                            The red sections points to where north is.
                            Compared to your physical orientation, not the map on your screen.
                            Brian McG 2 Replies Last reply
                              North is north is north, if the map is north up then north is up
                              In north up mode should the red section on the compass not always be at the top & not change?
                              • Brian McG Brian McG
                                @Brian-McG Evidently only if you are heading North all the time 🙂
                                • StanisÅ‚aw
                                  Stanisław
                                  Stanisław
                                  I think in north-up map orientation, the red segment should simply disappear, as it is not useful 🙂
                                  Staszek
                                    #17
                                    @Corjan-Meijerink apologies I think I now see your logic about your physical orientation & the direction of the altitude pointer, although for me it took some mental gymnastics to get there
                                    the way I think it is working is you have to discount everything else in the MRA display & treat the altitude pointer compass as a separate device, like imagining an old fashioned compass sitting on the fuel cap of your bike
                                    if I am riding heading east, then north is on my left shoulder & the altitude pointer compass wil point to the left of my phone screen
                                    if I am riding heading west, then north is on my right shoulder & the altitude pointer compass will point to the right of my phone screen
                                    again apologies but for me it was just not an intuitive bit of UI
                                    • LennyO
                                      I also had a hard time with this....
                                      I guess the simplest way to grasp the Red segment position in relation to your movement is to imagine yourself sitting inside the elevation circle heading in the 12 o'clock direction.
                                        It’s completely correct! Has no relation with the map. Indeed like an actual compass strapped om your screen.
                                        It makes sense but in north up it’s confusing.
                                        Pinning it north or hiding it will make most sense I guess.
                                        • Con Hennekens
                                          It seems current generations do not have much experience with (analogue) compasses anymore 😉
                                          Guzzist 1 Reply Last reply
                                          • 4
                                          Stanisław
                                          Stanisław
                                          Stevedo 6 0
                                          Stevedo 6 0
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                          • Routing issue
                                          • Live tracking
                                            557
                                          • Bar Buttons problems
                                            Gert Jan Bastiaans
                                            Gert Jan Bastiaans
                                          • Automatische routeaanpassing bij werkzaamheden gaat vreemd.
                                          • Overlapping routes
                                            281
                                          • Search from AA Auto not working
                                            peha
                                            peha
                                          • A13 Favorites and POIs how is the difference now in the new planner
