  4. Auto skip many waypoints by itself while I was on route. [5.2.0 - 474]
46 Posts 12 Posters 7.7k Views 4 Watching
  • LennyO LennyO
    @Marinus-van-Deudekom 100%! I am aware of that. Thos was the only thing I could spot on the route.
    But this should not the cause the problem with crazy skipping.
    @LennyO totally agree with you
    I hope that @m.-schrijver has send in the log files so Corjan can have a look at those
      Please remind me. How can i download the log files
      • RetiredWingMan
        Long press on the version number.
          Today i noticed also something in autoskipping procedure. I don't know if the rootcause is the same. But still i write it here.
          • From my current position i need to drive approx. 20 km before i'm on the route.
          • My standard setting is "Closest point" as startpoint when (re)starting a route.
          • Auto skipping is enabled as a default setting.
          Today MRA auto-selected "point 7" of the route as startingpoint. I changed this manual to "point 2". MRA created a route from my position to "point 2". So far nothing strange.
          Pretty after riding away from the where i started, i did need to deviate. MRA did a recalculation and skipped to "point 7". The recalculation was expected but auto-skipping to "point 7" not. Changed manual back to point 2 and keep on driving. A bit further and nicely on (pre-)route, MRA started a recalculation and auto-skipped to point 7. This time both were complete unexpected.
          • Marinus van Deudekom
            My guess is that it's normal behavior because you've stated that MRA saw nr 7 as the nearest point therefore skipping 1 to 6
              You can see it as normal behaviour. But there are more ways to look at it.
              The selected startpoint of the route is kind of an endpoint for the extra added part of the route. An endpoint normally doesn't change.
              Another point of view. When you are riding the route and you are deviating from the route and the next waypoint is still ahead of you. The navigation won't skip this one either.
              BMcG 1 Reply Last reply
                BMcG
                BMcG
                BMcG
                @M.-Schrijver I agree with @marinus-van-deudekom the system is pretty much doing what you asked it to do
                your settings "My standard setting is "Closest point" as start point when (re)starting a route." set the system up to designate point #7 as the start
                when this is locked into MRA & you then deviate & cause a recalculation, it is going to recalculate to point #7
                  That is just a different opinion. When i select a different point to start from, i expect the navigation stick to this point. No matter what happens during the trip to that selected point. Otherwise there is no reason to select a different point.
                  There are only 2 options. Startpoint (first point) or closest point. Either way following your explanation. In both situations i don't gonna be where i want to be.
                  • RetiredWingMan
                    I agree that MRA should not have skipped waypoints to wp7 on a recalculation.
                    • stuart marritt
                      stuart marritt
                      stuart marritt
                      There is a simple solution to these issues!
                      Turn off auto skip waypoints!
                      We had similar issues where it would randomly skip waypoints. There is 7 of us that sometimes we all had the problem and other times it was two or three of us.
                      We have all turned off auto skip waypoints and we skip them as and when we need to manually.
                      The next issue we need to figure out is why sometimes 2 people in the group end up with a different route than the one that was planned! coincidentally its the two who are using offline maps but that's for a different thread
                      paul69 M. Schrijver 2 Replies Last reply
                        sorry this has nothing to do with the OP, just thought I'd comment on the above.
                        funnily enough, I had this issue during the last weekend. me and a ridding buddy spent two days in lakes, I planned the routes on my computer, and as usual I always use the compare tool to make sure there are no nasty surprises.
                        My friend accessed the routes through the friends tab, both our devices are set up the same way in settings, although mine does not have internet as no SIM card, so obviously offline navigation. Android on rugged tablet.
                        He uses his phone iPhone 16 using NN also with offline navigation enabled.
                        when we compared the routes on our devices, both of the routes had changed on his, not a huge amount, but enough to make it like the red arrows at some junctions. some of the waypoints for him were skipped and others tried to get him to go back, did not happen on mine.
                        I could not understand the reason for this, I checked all settings and everything was exactly the same.
                        I think it might be something to do with internet access even tho offline nav is enabled, this is the only difference in our set up, save for android and IOS.
                        it did not spoil the rides as we were aware of the parts where NN would try to send him a different way.
                        K1600 GTL
                        iPhone 13 Pro, carpuride 702b
                          A better solution. Use no points at all.
                          stuart marritt 1 Reply Last reply
                          • RetiredWingMan
                            Went out for a 400km ride today. Everything worked great. Did a detour manually due to construction. MRA attempted to reroute me 4 times and then skipped a waypoint and I was back on route. Maybe next time I'll try the new feature for devouring around construction.
                            • paul69 paul69
                              BMcG
                              BMcG
                              BMcG
                              @paul69 did you both have the same version of offline maps loaded?
                              if the underlying map data is different then the routing calculation between points could calculate differently
                              what happens if you set both devices to ride the paths as a track?
                              paul69 1 Reply Last reply
                              • BMcG BMcG
                                hi @Brian-McG
                                thanks for the map tip, TBH that was the one thing I did not check, but the roads we were on are well established and have never changed in many years.
                                We were riding routes as routes.
                                I had thought of changing it to "as tracks" although as I wrote it did not cause any riding issues, as we were aware of the discrepancies.
                                It was more about pointing out the issue, as the one which had changed had Internet access, but offline nav enabled.
                                it may be a useful point for anyone else if they come across this issue when riding in groups, which I guess would be better for everyone to use tracks.
                                One point on that, when I select this option, I always get the "go online for better track navigation" or words to that effect, can't remember off hand. My NN is on a tablet with no SIM card, therefore never any internet access.
                                K1600 GTL
                                LennyO BMcG 2 Replies Last reply
                                • paul69 paul69
                                  hi @Brian-McG
                                  @paul69 By definition, calculated route when offline, may not be exactly the same as you planned.
                                  And the fact that the only people who had it different are the ones using the offline navigation kind of proves it.
                                  Also, did they have "Navigate routes as tracks" selected?
                                  Thx!
                                    stuart marritt
                                    stuart marritt
                                    stuart marritt
                                    Well its not!
                                    You plan a route to go where you want to go and not let the navigation decide
                                    • paul69 paul69
                                      hi @Brian-McG
                                      BMcG
                                      BMcG
                                      BMcG
                                      @paul69 the roads may well be established but if one of the sets of map data contains data about a road being impassable i.e. closed for construction or if the map data weights a road with a different average speed then the calculation of route could possibly result in a different being calculated
                                      • LennyO LennyO
                                        Thx!
                                        hi @LennyO
                                        not entirely sure what you mean here. Why would it calculate an already planned route. The routes are planned on the MRA website and automatically sync to the devices when NN opened, my routes do not change when I use NN, (lets not discuss seasonal closures etc)
                                        the one with internet access had the route changed on their device, not mine (without Internet), for me the route remained as we had planned on the laptop, we both had offline navigation enabled in settings
                                        did not have routes as tracks.
                                        K1600 GTL
                                        LennyO 1 Reply Last reply
                                        • BMcG BMcG
                                          suppose that's a fair point, one to remember for the future when arranging rides with others.
                                          TBF this can be the only explanation as nothing else would explain it.
                                          Take note all who read this, forget about the online, offline, internet or no internet, debacle, check your maps, obviously before you leave home on your trips with your mates 😂
                                          K1600 GTL
                                          BMcG
                                          BMcG
                                          stuart marritt
                                          stuart marritt
                                          ErikMatthezing
                                          ErikMatthezing
                                          Ronnie Moore
                                          Ronnie Moore
                                          Reid Squier
                                          Reid Squier
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
