  4. Allowing Highways
Allowing Highways
6 Posts 4 Posters 610 Views 3 Watching
  • Mark Williams 5 0
    Mark Williams 5 0
    Mark Williams 5 0
    When I enter a destination on the MRA Android app and select the allow Highways option, the app will not navigate using highways (motorways as we call them in the UK. I have the Gold and MRA Navigation Next subscriptions.
    The allow Highways options will be toggled off again when I check. I toggle it on, app still won't navigate using highways and when I look at the routing options again, allow Highways will be toggled off.
    I really want to use satnav that will navigate via highways/motorways.
    Brian McG 2 Replies Last reply
    • Hubert Thoring
      For use, I recommend reading the MRA manual. But to do this, you have to go to the web planner.
      The MRA Navi app routes on the highway if you want it, the settings may not contradict each other✅
      • Mark Williams 5 0 Mark Williams 5 0
        This is definitely not normal behaviour if your just selecting "Destination" from the route options draw in the app & choosing a place to navigate too
        It sounds like the "Avoidance Option - Highways" setting has become fixed rather than selectable
        Have you tried toggling any of the other avoid options to see if they also reset?
        You could try force stopping the app to see if that resets anything or maybe try logging in/out of the app to see if that clears something
        Mark Williams 5 0 1 Reply Last reply
        • Brian McG Brian McG
          Mark Williams 5 0
          Mark Williams 5 0
          Mark Williams 5 0
          @Brian-McG yes I even cleared the data and app cache. Also uninstalled reinstalled.
          Thanks for taking the time to reply.
          I sense I'll be using MRA for route planning for motorcycle tours but will have to stick with Waze if I just want navigation to a single destination. Shame as I paid for lifetime membership
          LennyO 1 Reply Last reply
            @Mark-Williams-5-0 Hi, Mark!
            If my understanding is correct, the "Destination" option is an implied "Scenic" route to various degrees that you can select. And om my Android it does not use Highways even when allowed.
            To just get to your destination (again could be controlled by avoidances), try using the option "MRA Routeplanner / Create new routes".
            It uses Highways then.
              @Mark-Williams-5-0 I think we may be talking at cross purposes or different things as this is not adding up at all correctly for me & does not match what I see when I "enter a destination". You say.....
              For me this means a simple A > B route from your location to a destination
              To do this I would select "Destination" from the route options draw,
              Search for & then select my destination, followed by pressing the Navigate button & my route options would be shown
              As you can see when select Leicester as my destination from west London it definitely allows me to use motorways / highways as it gives me the choice of routing via the M1 or M40
              Under "Avoidance options" the "Highways" button is the default green as an allowed road
              I think to help further you will need to explain your steps a bit more fully
              Mark Williams 5 0
              Mark Williams 5 0
              • Pay for beta?
                Peter Bijnsdorp
                Peter Bijnsdorp
              • Live payments enabled
                Edwin_M
                Edwin_M
                185
                LE DIZES Freddy
                LE DIZES Freddy
                1.1k
                Brett Bartick
                Brett Bartick
                TomOnTour
                TomOnTour
              • import in beta-mra failed
