  3. Skipping waypoints for no reason
5 Posts 3 Posters 405 Views 1 Watching
  • stuart marritt Offline
    stuart marritt
    So today we went for a ride and 3 of us all had the route on MRA which is pretty normal for us and we never had an issue
    The route was created by one of the other group riders
    We stopped at a cafe which was just past waypoint 14 on the route had breakfast and back on the bikes to go when we noticed that MRA had recalculated and skipped points 15,16 & 17 and was taking us straight to 18 on all 3 devices
    Link to the route https://www.myrouteapp.com/route/open/13816749
    The route is using openstreet which then makes it navigate as a track
    All our phones where set with automatically skip waypoints turned off!
    So can anyone suggest a reason that this has happened?
    This is the first time we have had this happen
    Thanks
    Stu
    Marinus van Deudekom RetiredWingMan 2 Replies Last reply
      Thanks
      Stu
      Marinus van Deudekom Offline
      @stuart-marritt the moment you start using a OSM map route it will be recalculated to the Here map. In oktober wordt the original route could be compromised and should be treated as potentially not what you expected it to be
      stuart marritt 1 Reply Last reply
        stuart marritt
        one of the riders restarted the route and the waypoints was all back to how they should be
        Same with mine once we got to another stop.
        The route was fine and navigating OK before the slightly off route and the stop at a cafe then upon setting off the 3 points mentioned had skipped themselves ?
          Thanks
          Stu
          RetiredWingMan Offline
          @stuart-marritt when you stop, MRA navigation should be paused (stop navigation) and started again once you are ready to continue. The issue is that as you move around MRA thinks you are still navigating and gets confused with your movement. This is made worse with the Here map issue that spins the map around and sometimes causes the app to do recalculations.
            stuart marritt
            I use a separate phone that is left on the bike.
            The others don't and we have never had this issue before
            We haven't skipped any waypoints and we haven't got auto skip waypoints so why has it skipped 3 waypoints
            stuart marritt
            stuart marritt
            • Carpuride scherm vast
              De Ploey Georges
              De Ploey Georges
              1.3k
              14.6k
            • How can I change the verbal navigation directions from male to female?
            • New update 5.2.1
              15
              18
              715
              374
            • Apple Carplay - navigatie instructies zichtbaar, maar kaart niet??
            • Camperroutes
              De Ploey Georges
              De Ploey Georges
            • Wegwerkzaamheden / Road works
