<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Skipping waypoints for no reason]]></title><description><![CDATA[<p dir="auto">So today we went for a ride and 3 of us all had the route on MRA which is pretty normal for us and we never had an issue</p>
<p dir="auto">The route was created by one of the other group riders</p>
<p dir="auto">We stopped at a cafe which was just past waypoint 14 on the route had breakfast and back on the bikes to go when we noticed that MRA had recalculated and skipped points 15,16 &amp; 17 and was taking us straight to 18 on all 3 devices</p>
<p dir="auto">Link to the route <a href="https://www.myrouteapp.com/route/open/13816749" rel="nofollow ugc">https://www.myrouteapp.com/route/open/13816749</a></p>
<p dir="auto">The route is using openstreet which then makes it navigate as a track</p>
<p dir="auto">All our phones where set with automatically skip waypoints turned off!</p>
<p dir="auto">So can anyone suggest a reason that this has happened?</p>
<p dir="auto">This is the first time we have had this happen</p>
<p dir="auto">Thanks<br />
Stu</p>
]]></description><link>https://forum.myrouteapp.com/topic/11251/skipping-waypoints-for-no-reason</link><generator>RSS for Node</generator><lastBuildDate>Sat, 27 Jun 2026 23:43:41 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11251.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Jun 2026 19:55:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Skipping waypoints for no reason on Sat, 27 Jun 2026 20:24:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marinus-van-deudekom" aria-label="Profile: Marinus-van-Deudekom">@<bdi>Marinus-van-Deudekom</bdi></a> <a href="/post/80187">said</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuart-marritt" aria-label="Profile: stuart-marritt">@<bdi>stuart-marritt</bdi></a> the moment you start using a OSM map route it will be recalculated to the Here map. In oktober wordt the original route could be compromised and should be treated as potentially not what you expected it to be</p>
</blockquote>
<p dir="auto">one of the riders restarted the route and the waypoints was all back to how they should be</p>
<p dir="auto">Same with mine once we got to another stop.</p>
<p dir="auto">The route was fine and navigating OK before the slightly off route and the stop at a cafe then upon setting off the 3 points mentioned had skipped themselves ?</p>
]]></description><link>https://forum.myrouteapp.com/post/80188</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80188</guid><dc:creator><![CDATA[stuart marritt]]></dc:creator><pubDate>Sat, 27 Jun 2026 20:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping waypoints for no reason on Sat, 27 Jun 2026 20:19:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuart-marritt" aria-label="Profile: stuart-marritt">@<bdi>stuart-marritt</bdi></a> the moment you start using a OSM map route it will be recalculated to the Here map. In oktober wordt the original route could be compromised and should be treated as potentially not what you expected it to be</p>
]]></description><link>https://forum.myrouteapp.com/post/80187</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80187</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Sat, 27 Jun 2026 20:19:15 GMT</pubDate></item></channel></rss>
