  4. Waypoints and POIs disappear while moving/zooming the map in web planner
10 Posts 4 Posters 805 Views 1 Watching
  • Tom Balmer
    Tom Balmer
    Tom Balmer
    Occasionally, but repeatedly, the waypoint display disappears when the route is open. Usually, closing and reopening the route fixes the problem. Now this is suddenly happening with POIs as well: I choose Restaurants and I display them, and it works at first. Then, after I’ve moved things around on the map a bit, they suddenly disappear and only flash briefly when I zoom out and back in. It looks like a map display or rendering issue, because the POIs are shown correctly at first.
    Any tips on what the problem might be? I’m using the web version with DuckDuckGo on a Mac.
    Thanks,
    Tom
    • Marinus van Deudekom
      That means that your zoom level is either to big or to small. Yes it takes some practice to get the hang of it.
      • Tom Balmer
        Tom Balmer
        Tom Balmer
        With the POIs, yes, usually it's like that. But the waypoints should be visible all the time, correct?! They disappear after a moment of planning. Then the same with the POIs - they should be visible all the time after zooming in, I'm aware of that, but they don't, that's my point.
        • Tom Balmer
          Tom Balmer
          Tom Balmer
          The same zoom level, first the waypoints and POIs are visible, then, see the second screenshot, they disappeared.
            If your zoom level is far out the waypoints disappear as wel
              Waypoints should always be visible at all zoom levels.
              • Tom Balmer
                Tom Balmer
                Tom Balmer
                wrote on last edited by Tom Balmer
                Additional observation: the POIs and waypoints do not seem to be removed from the map logic. When I move the mouse over the position of an invisible POI or waypoint and click it, the corresponding POI/waypoint information window still opens. So the objects are still there and clickable, but their icons are no longer rendered visually.
                This happens after panning and zooming for a while. The icons briefly reappear during zooming, but disappear again once the map has finished rendering. This happens with both DuckDuckGo and Safari (with MacOs Tahoe 26.5.1).
                • Tom Balmer
                  Tom Balmer
                  Tom Balmer
                  • Tom Balmer
                    Tom Balmer
                    Tom Balmer
                    Next test: It seems to work with Edge. So to me, it definitely looks like a display issue that depends on the browser being used...
                    • Tom Balmer Tom Balmer
                      @Tom-Balmer, I would not be surprised if it is a local caching problem. Try to remove cached data for myrouteapp.com.
                      Tom Balmer
                      Tom Balmer
                        138
                        Jörg Neudert
                        Jörg Neudert
                        4.7k
                        4.8k
                      • Hallo, wéér een nieuwe gebruiker !
                      • Vergrendel scherm zet alles op z'n kop
