  4. A routing issue
A routing issue
7 Posts 5 Posters 782 Views 1 Watching
  • Mark Coughlin Offline
    Mark Coughlin
    I am fine tuning a tour round Europe at the end of June and I'm having a routing issue. According to google maps the route is open but MRA isn't allowing it, even with seasonal closures disable.
    I want to do this route from Sembrancher to Saxon.
    https://www.myrouteapp.com/en/social/route/12505317?mode=share
    • Mark Coughlin Mark Coughlin
      Nick Carthew Offline
      @Mark-Coughlin Move 13 a little closer to 14.
        Mark Coughlin
        Can't believe that I didn't do that as I normally do, but the massive diversion made me think that there had to be a problem.
        Thanks
        Mark
        • nomko Offline
          nomko Offline
          Banned
          @mark-coughlin
          What is the setting of your route optimisation? Have you set it to Fastest or to Shortest?
          One will have a different approach to a route than the other.
          If the route optimisation is set to Fastest: yes the route will be as shown in your screenshot because the route could be faster between points 12 and 16.
          But set to Shortest, the route should go from 12 to 13 to 14 to 15.
          Something to check as well 😉
          • Geerd Offline
            Geerd Offline
            Geerd
            wrote on last edited by Geerd
            I'm planning a trip also..i have the same issue's. Its since the last update.
            You need to set a lot of more points on the map to direct the rout.
            Whit the last version it just would go via Schonsee en Eslarn
            • Geerd Geerd
              What versions are you talking about? App versions have no influence on the web-planner at all, and the web-planner has not been updated.
              • Geerd Offline
                Geerd Offline
                Geerd
                Uhmzz oke strange then, i never had did "issue" before.
                Geerd
                Geerd
                Mark Coughlin
                Mark Coughlin
                • Welke instelling
                  1.1k
                • opslaan naar plantomtom
                  chris 18
                  chris 18
                  484
                • Seizoen sluitingen wegen
                  PAT62
                  PAT62
                • The slow death of Zumo...
                  Thomas Schäfer
                  Thomas Schäfer
                • New Zealand Touring Group
                • Rejoining routes
