  4. A routing issue
A routing issue
7 Posts 5 Posters 913 Views 1 Watching
  • Mark Coughlin
    Mark Coughlin
    Mark Coughlin
    I am fine tuning a tour round Europe at the end of June and I'm having a routing issue. According to google maps the route is open but MRA isn't allowing it, even with seasonal closures disable.
    I want to do this route from Sembrancher to Saxon.
    https://www.myrouteapp.com/en/social/route/12505317?mode=share
    • Mark Coughlin Mark Coughlin
      @Mark-Coughlin Move 13 a little closer to 14.
      • Mark Coughlin
        Mark Coughlin
        Mark Coughlin
        Can't believe that I didn't do that as I normally do, but the massive diversion made me think that there had to be a problem.
        Thanks
        Mark
        • nomko
          Banned
          @mark-coughlin
          What is the setting of your route optimisation? Have you set it to Fastest or to Shortest?
          One will have a different approach to a route than the other.
          If the route optimisation is set to Fastest: yes the route will be as shown in your screenshot because the route could be faster between points 12 and 16.
          But set to Shortest, the route should go from 12 to 13 to 14 to 15.
          Something to check as well 😉
          • Geerd
            Geerd
            Geerd
            wrote on last edited by Geerd
            I'm planning a trip also..i have the same issue's. Its since the last update.
            You need to set a lot of more points on the map to direct the rout.
            Whit the last version it just would go via Schonsee en Eslarn
            • Geerd Geerd
              What versions are you talking about? App versions have no influence on the web-planner at all, and the web-planner has not been updated.
              • Geerd
                Geerd
                Geerd
                Uhmzz oke strange then, i never had did "issue" before.
                Geerd
                Geerd
                Mark Coughlin
                Mark Coughlin
                • Missing info from CarPlay
                • Custom POI color and icons
                • File en omrijden
                  Robineke
                  Robineke
                • A11 Making the Algorithm More Visible – Overview and Planner File
                • Geen pictogram van een motor
                • F003 POI Folder & group missing in the app
                • Friends Routes selection
