  4. Points between points
11 Posts 5 Posters 2.0k Views 2 Watching
  • Arjan de Vries
    Arjan de Vries
    Arjan de Vries
    Is there a possibility to insert a waypoint some down the route without becoming the last point. So if you have 100 points can I put one between 30 and 31 for example?
      @Arjan-de-Vries If you’re using the route planner in the app, a long press in between route points will add a new route point in sequential order.
      If you’re using the website, hover the mouse cursor over the route line until you see the black ball, then click.
      Arjan de Vries 1 Reply Last reply
        Arjan de Vries
        Arjan de Vries
        Arjan de Vries
        @Nick-Carthew mmmm.. I think I am doing something wrong here. When I am in the app on the iPhone or iPad and want to insert a waypoint it gives me the last number and langpress does not work. See picture.![alt text](Schermafbeelding 2025-01-05 om 10.01.22.jpeg image url).
        If I press the yellow button it puts a waypoint where I want it but it will be the last number (in this case I wanted one between 2 and 3 but it gives 115.).
        a white mouse on the motorbike Nick Carthew 2 Replies Last reply
          @Arjan-de-Vries To insert the new point correctly, you must first place the new point on the route between the points where it should end up and then you can move it to the correct position!
            @Arjan-de-Vries Do not use the yellow button, long press on the route line to add a new route point.
              @Nick-Carthew Look at my example between route points 2 and 3. A long press and I can add a new route point 3 and the old route point 3 now becomes 4.
              Arjan de Vries LennyO 2 Replies Last reply
                Arjan de Vries
                Arjan de Vries
                Arjan de Vries
                @Nick-Carthew WORKS! Thanks!
                  @Nick-Carthew Hi, Nick!
                  I tried adding the new waypoint in my Android and it only adds it as last. And I am at the max magnification ant long pressing exactly on the existing line....?
                  App version 5.0.4-451
                  Thanks!
                  • LennyO LennyO
                    Thanks!
                    @Lenny-O, I checked this for you, and it still works. It's a bit finicky though. Maybe your fingertip is not very round 😉 try pressing a little besides the line. It really takes some practice.
                      @Con-Hennekens Will do! Thank you, Con!
                        @Con-Hennekens It worked, but it sure is a PITA to do... 🙂
                        Arjan de Vries
                        Arjan de Vries
                        • Migration of my data
                          Solo1138
                          Solo1138
                          98
                        • Here Terrain maps style
                          Jerry Brok  Wacky
                          Jerry Brok Wacky
                        • MRA AI Routeplanner credits
                          Ro 3
                          Ro 3
                        • AI Weather forecasts
                        • Route direct naar Garmin drive
                        • Route niet op de weg
                          Marcel Versluis
                          Marcel Versluis
