  4. Proposal for an algorithm to guide around unexpected road closures
41 Posts 12 Posters 11.5k Views 7 Watching
  • BMWBiker58 BMWBiker58
    I’m trying to understand the suggested solution by tapping a point beyond the road closure.
    Wouldn’t the algorithm still try to guide me to the new route point via the closed exit, as that would be the quickest way there?
    Furthermore, I do not consider this practical, as you are not allowed to stop at the closed motorway exit just to set a new route point on the small display.
    In my opinion, there should be a prominent button that tells the algorithm that the exit you have just passed cannot be used and that a route to the planned destination beyond the closure must be found.
    Axel Härtl
    Axel Härtl
    Axel Härtl
    @BMWBiker58
    Exactly my opinion. 👍
    BMW R 1200 RT
    Tourenorientiert
    MRA lifetime member
      @BMWBiker58, And it should guess which point that is I suppose?
      BMWBiker58 1 Reply Last reply
        @BMWBiker58 said in Proposal for an algorithm to guide around unexpected road closures:
        Let’s say the exit is closed and you can’t take that exit; you’ll have no choice but to carry on driving......
        The system would then immediately guide you to the point you selected beyond the closure and then continue along the route as standard.
        If, by chance, a point has been set on the exit, this is irrelevant, because by manually selecting a point beyond the closure, you have skipped all the previous ones.
        Your point that you can’t stop on the motorway is correct… so just carry on driving and take the next exit (there you can stop if necessary and start the process to skip the waypoint).
        You don’t need to set a new point on the map either; simply select an existing one after the road closure.
        Either press and hold the next expected waypoint in the top right-hand corner of the display; this will take you to the next waypoint, and you can repeat this several times.
        Alternatively, in the waypoint list, tap a point on the route after the roadworks, and it will navigate you there.
        Option 3: Select a existing point on the route on the map after the road closure, and it will navigate you there.
        In all 3 cases, the preceding points are skipped.
        Personally, I’ve treated myself to the SilverFox C1 Bluetooth controller, which allows me to zoom, skip waypoints and do much more without having to stop.
        Find out more on the MRA support page
        BMW R 1250 GS
        DMD-NOR7E 7"
        SPC Universal mount
        Motorola Edge 40 "offline"
        Sena SLR 3
        Sena 50 R
        • BMWBiker58
          BMWBiker58
          BMWBiker58
          Thank you for explaining the options.
          My concern (or lack of knowledge), however, is that the algorithm will try again to reach the newly selected next route point via the closed exit. Simply because the route through the closure is the shortest/quickest.
          In that case, it would be pointless whether you chose the first, second, third, etc. route point beyond the closure.
          In my opinion, there ought to be a way to block the closed exit with a single tap, so that the system doesn’t keep trying to reach the next route points via that exit.
            BMWBiker58
            BMWBiker58
            BMWBiker58
            @Con-Hennekens The app could simply head for the next waypoint after the roadblock. However, it must not do so via the blocked exit, but must find its own route.
            If the next waypoint after the roadblock is also inaccessible, it would simply have to take the one after that.
              #37
              @BMWBiker58 Provided your route doesn’t wind its way around the closed motorway exit like a snail, I don’t see any danger here.
              As already described, the app will guide you to the selected waypoint, and it doesn’t matter whether that’s a shaping or a Via point.
              In your example, you couldn’t leave the motorway at the closed exit... as soon as you selected the next exit and left the motorway, you’ll be guided to the new selected point, possibly just outside the motorway, passing close to your closed exit, but of course only if your destination is near the closed exit.
              If your destination is not next to the closed exit, you will not be guided there.
              To be absolutely sure that you are not guided back, please skip one or two more waypoints than might be necessary.
              The app will definitely not navigate you to the closed exit...
              It is understandable that you would want to inform the app that this exit is closed, but it is absolutely not necessary.
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
              Axel Härtl 1 Reply Last reply
                Axel Härtl
                Axel Härtl
                Axel Härtl
                wrote on last edited by Axel Härtl
                #38
                As part of this discussion, I’d like to share a real-life example—one that’s both amusing and frustrating.
                This week, I went on a motorcycle ride that I had planned to be about 130 km long.
                During the ride, I encountered about 10 road closures (It's spring time and everybody is working on new roads.). And here’s the big thing:
                • Not a single one of these closures was marked on the Here map.
                • Only about half of the closures even had detour signs. There were simply closures with no detour instructions.
                But the best is yet to come.
                In one town, there were several construction zones whose detours were obviously not coordinated.
                • Act 1: Road closure with detour number 1. I followed these signs.
                • Act 2: Before detour number 1 had even ended, I came across the next road closure, number 6, which I then took.
                • Act 3: Before detour number 6 was even over, there was another roadblock on that detour route, this time with detour signs that had no number. I took that route and was directed by the detour signs back to roadblock number 1. Bingo.
                • Act 4: Please skip to Act 1.
                I then switched from MRA to Google Maps. In MRA’s defense, it should be noted that Google Maps couldn’t handle this chaos either.
                So I fell back on my tried-and-true navigation method from 50 years ago: an analog watch and the position of the sun.
                After a long ride, I finally arrived where I had originally intended to go. 185 km — but on a motorcycle, the journey is the destination.
                That's the hard reality.
                BMW R 1200 RT
                Tourenorientiert
                MRA lifetime member
                • Axel Härtl Axel Härtl
                  @Axel-Härtl said in Proposal for an algorithm to guide around unexpected road closures:
                  If we all keep this in mind, problems will be much less a problem 😉
                  I don't envy your experience, but must also admit that in my journeys I never experienced it so bad. Lucky you! 😉
                    #40
                    I have now promised to look into it 🙂
                    https://forum.myrouteapp.com/topic/10830/new-beta-5.1-457
                    Edit: I know only beta testers can read that post. No, people cannot sign up for beta anymore. Will become a public announcement within 2 weeks max.
                    • Axel Härtl
                      Axel Härtl
                      Axel Härtl
                      Sounds great, @Corjan-Meijerink
                      Of course my recent post was meant to be a funny story. Although there were some serious points.
                      Best, Axel
                      BMW R 1200 RT
                      Tourenorientiert
                      MRA lifetime member
                      Òscar
                      Òscar
                      Stanisław
                      Stanisław
                      Axel Härtl
                      Axel Härtl
                      BMWBiker58
                      BMWBiker58
                      • MRA Studio export speed
                      • Hiya from UK
                        Russ Nattrass 1
                        Russ Nattrass 1
                      • geeft routepunt niet weer
