  4. How to exclude short time road blocks during navigation
23 Posts 7 Posters 5.9k Views 4 Watching
  • Axel Härtl
    Axel Härtl
    Axel Härtl
    wrote on last edited by Axel Härtl
    Hello @Corjan-Meijerink,
    I’ve been an enthusiastic user of MRA for years (including as a Lifetime Member).
    There’s one issue I keep running into, and I’d like to clarify it.
    It happened to me many times that I suddenly come across a last-minute road closure that isn’t shown on the maps and therefore not accounted for in the planning.
    With Calimoto (yes, yes, that was a long time ago), I could dynamically block the section of road ahead of me (1 km, 5 km, ...) so that the navigation would route me around the blocked section.
    With MRA, I don’t know how to do that. If I simply take a different route, MRA guides me back to the exact spot that’s blocked after a few minutes. Then I have to switch to Google Maps, which I’d really try to avoid.
    What is MRA’s approach to roads that are blocked at short notice? What should the user do to avoid being directed into the roadblock over and over again? Just deleting one or two shaping points ahead doesn't help.
    Thanks for your answer.
    Best, Axel
    BMW R 1200 RT
    Tourenorientiert
    MRA lifetime member
    Nick Carthew HABVEN aka MrMRA 2 Replies Last reply
    • Axel Härtl Axel Härtl
      Best, Axel
      @Axel-Härtl If the road closure is unknown then how can the app respond?
      You follow the local diversion signs and skip any waypoints that are in the closed section.
      Axel Härtl 1 Reply Last reply
        Axel Härtl
        Axel Härtl
        Axel Härtl
        @Nick-Carthew
        Hi Nick, the easy answer is: MRA should use a similar algorithm as Calimoto.
        It happend to me pretty often that a detour is not shown by signs. So I just drive left or right in front of the block. That doesn't help as I explaind in #1.
        BMW R 1200 RT
        Tourenorientiert
        MRA lifetime member
        • Rae Sewell
          Rae Sewell
          Rae Sewell
          Not just Calimoto but also the Tomtom Go Expert app has the facility to avoid the next few yards or miles.
          • Nick Carthew
            You can select to see the original route, this appears as a white line. If there are no local diversion signs (not very common to see this) then you navigate around the closure back to the original route and skip whatever waypoints that you need to.
            This is a perfectly easy solution, personally I do not wish for a clone of Calimoto or TomTom Go but that’s just my opinion.
              Axel Härtl
              Axel Härtl
              Axel Härtl
              @Nick-Carthew
              Hi Nick, to be honest - that seems much too complicated for me - especially on a small mobil phone.
              What's the reason not to implement a solution like other navigation systems? I'm shure most users will be very pleased with such a functionality.
              BMW R 1200 RT
              Tourenorientiert
              MRA lifetime member
                @Nick-Carthew
                @Axel-Härtl, The reason is that usually it is unknown how long the blockage is. You can assume 1 km or 5, but there is no realism in it. ALSO, usually a detour is on the signs on the road. Just follow that advised detour. ALSO, If you block say 1 km of road but the detour puts you on the road 3km further, your solution would send you back for 2km. So... I am happy with the way it is now...
                  Axel Härtl
                  Axel Härtl
                  Axel Härtl
                  Hm, I understand what you are saying. Your are right - the lengh of the blockage is not known a priori. So the software has to deal with that uncertainty (see my point #2 below).
                  1: If there are detour signs, following those is definitely the best choice. Of course some shaping, or - more important - via points have to be deleted.
                  -a: when are I back on the original route?
                  -b: which via points did I miss and have to delete them? (Assuming that shaping points are skipped automatically.)
                  You see - pretty much to do. Not very user friendly.
                  2: The algorithms of Calimoto and friends don't guide you back towards the detour you just took. Once you're back on the original route, the software continues to guide you in the direction of your original destination. That means, that the estimation of the length of the blockage is not crucial. If you choose a too long blockage, the detour will be longer. That's it.
                  So I keep my question open: why not a similar philosophy in MRA as in comparable navigation systems (of course, MRA is not comparable to any other system. 😳 😀)
                  Best, Axel
                  BMW R 1200 RT
                  Tourenorientiert
                  MRA lifetime member
                    Best, Axel
                    @Axel-Härtl As I have said in a previous comment, in the highly unlikely event of a road closure not having local diversion signs, using your inbuilt navigation device (common sense) you look at your screen and see the white line of the original route. It really is not difficult to navigate back to it.
                      Axel Härtl
                      Axel Härtl
                      Axel Härtl
                      @Nick-Carthew
                      Thanks, Nick. You have a very good point.
                      One could see, wether there is a via point (or an unskipped shaping point) on the white line. Then it is easy to delete them. Perfect.
                      Thanks - your solution will help me in future definitely.
                      Best, Axel
                      BMW R 1200 RT
                      Tourenorientiert
                      MRA lifetime member
                        @Nick-Carthew
                        Best, Axel
                        @Axel-Härtl You could always clear the blocked road like Corjan and I did in 2023 😁
                          Axel Härtl
                          Axel Härtl
                          Axel Härtl
                          @Nick-Carthew
                          Again a very good point.
                          I will remember your solution the next time I'm facing a blocking.
                          BMW R 1200 RT
                          Tourenorientiert
                          MRA lifetime member
                          • BMWBiker58
                            BMWBiker58
                            BMWBiker58
                            I would also like to see better technical support in the event of sudden road closures. Unfortunately, I very often find that motorway exits are closed. This means you’re forced to drive past them. As a result, you’re directed in the opposite direction at the next junction, only to be led back to the closed exit after another U-turn. Especially when the closure is announced at very short notice, there are (as yet) no diversion signs. The advice to ‘navigate by sight’ back to the route is not helpful to me, particularly when you are in a completely unfamiliar area and have a poor sense of direction. Technical support that eventually guides you back onto the route would be the most useful improvement to the MRA NN app for me.
                            • Herman Veldhuizen
                              #14
                              last minute closures (caused by accidents typically) never have diversion signs. tomtomgo expert has indeed a useful feature to deal with such cases and it would be a useful addition to MRA. But if you ask me wether implementing it should get priority over some other issues my answer would be no.
                              • BMWBiker58 BMWBiker58
                                @BMWBiker58 said in How to exclude short time road blocks during navigation:
                                The app is very good but it cannot foresee sudden road closures. If you have to go past your intended motorway exit the app can recalculate your route, this has to be used alongside some common sense, therefore don’t take the next exit and go back in the opposite direction. You may need to skip some route points but if you use the “Show original route” option, when you have to leave your planned route and there are no local diversion signs, the white line of the original routes gives you a target to aim for.
                                I would urge everyone to test and practice this method before a real situation comes along, this way you know what to expect and how to deal with it.
                                  Best, Axel
                                  @Axel-Härtl said in How to exclude short time road blocks during navigation:
                                  No you don't... The only thing you need to do when you get back on th route, is long-press the next route point. That's it.
                                  I understand your wish for detection when you are back in the route, and I share that wish with you. But it simply cannot be done because of lack of support for such feature in the HERE platform. Maybe some time it will be possible, but don't hold your breath.
                                    Axel Härtl
                                    Axel Härtl
                                    Axel Härtl
                                    #17
                                    Thanks for your anwer.
                                    I more and more get the impression, that MRA can do a lot for users. Much more than I knew prior to this discussion.
                                    But on the other hand you need an IT exam to know all the tricks and features (short or long pressing a waypoint - difference during planning and navigating). But I'm keen to learn all features of MRA.
                                    Best, Axel
                                    BMW R 1200 RT
                                    Tourenorientiert
                                    MRA lifetime member
                                      Axel Härtl
                                      Axel Härtl
                                      Axel Härtl
                                      @Nick-Carthew
                                      Just a short comment. Tomtom navigation also doesn't know a sudden blocking in advance. It is not in the basic map.
                                      But they found a way to deal with it as Herman showed.
                                      BMW R 1200 RT
                                      Tourenorientiert
                                      MRA lifetime member
                                        @Nick-Carthew
                                        @Axel-Härtl Herman’s post is misleading, the blocked road is unknown therefore TomTom cannot avoid what is unknown. Also TomTom does not know how much of the route to avoid, so it isn’t a solution for your scenario
                                          #20
                                          @Nick-Carthew I recommend to try it. With tomtom you can mark any instruction on your route (like take the next exit) as to be avoided and tomtom will find another way to your destination. It then shows a white route representing the new way to your destination (in addition to the original blue route). And you will get navigation instructions on how to follow this new way. 1000010782.jpg 1000010784.jpg
                                          Axel Härtl
                                          Axel Härtl
                                          BMWBiker58
                                          BMWBiker58
                                          Rae Sewell
                                          Rae Sewell
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
