  4. Start route bij dichtstbijzijnde routepunt werkt niet
16 Posts 6 Posters 1.8k Views 2 Watching
  • RainerT RainerT
    ‘Next route point’ means:
    The route point closest to my current position. This may also lead back along the route.
    Or, in unfavourable circumstances, it may be the last one.
    The safest option is to let MRA search for the first waypoint as the starting point and then manually select the one that suits me. That one is then activated.
    RT
    Marinus van Deudekom Do not disturb
    @RainerT normally it does work like that
    • Philippe Veys Offline
      Philippe Veys
      When restarting the route after a (coffee)break, is there no other way then to press longtime on the next waypoint ? The function « Start at closest waypoint » is really missing in this app! I’m just back from a motor tour and selecting the next waypoint didn’t work, only from Start, the app crashed finally🤨
      Herman Veldhuizen Con Hennekens 2 Replies Last reply
      • Philippe Veys Philippe Veys
        Herman Veldhuizen Offline
        @Philippe-Veys Are you navigating a route as track? The 5.0 release always starts at the first waypoint (before that you could select start or nearest). There are some issues related to this (which I have reported).
        I dont know the implementation details but it could be wise for the app to focus first on the navigation ON the track and later try to solve the navigation TO the track.
        I have the setting Automatic-recalculation set to off and it is therefore a bit strange to see that the app finds a way to the track if I am not on it at startup.
          @Philippe-Veys said in Start route bij dichtstbijzijnde routepunt werkt niet:
          No it is not. Before pressing "Start", tap "Route settings", there it is.
          The correct way to pause a route, is to enter the menu, and tap "Stop navigation". A "Resume" button appears that always picks up where you left.
          If you navigate tracks or use the "Navigate route as track" feature, this is skipped indeed, since you are navigating a track. You will have to decide the point of entry yourself indeed.
            Philippe Veys
            Ok, I noticed that for some routes I made, I have the possibility to select Route Settings with possibility to choose Start at closest waypoint before I press Start, and for some I don’t.
            What could be the reason for this ? I don't use the routes as tracks. As I recall, I always create the routes the same way.
            Nick Carthew Con Hennekens 2 Replies Last reply
              Philippe Veys
              This post is deleted!
                Nick Carthew Online
                Nick Carthew Online
                @Philippe-Veys The ones without the option are tracks the ones with the option are routes.
                P.S I deleted your duplicate post.
                  Philippe Veys
                  I don't use tracks, I only create routes in MRA Routeplanner and use them in the MRA app on my motorbike, so that can't be the reason I think.
                    Nick Carthew Online
                    Nick Carthew Online
                    @Philippe-Veys Are you using an A -B route?
                    I see the option to Start from nearest waypoint
                      Philippe Veys
                      I’m using A to B route indeed. But I just noticed that if I create or change a route in the MRA app on my IPhone, I do have the options ! This must be a bug in the system 🥴
                        I think you do, you just don't know when a track is a track, so
                        no it is no bug...
                        Everything you do with roundtrip generator or curvy routes actually IS a track.
                        RainerT
                        RainerT
                        Philippe Veys
                        Philippe Veys
                          826
                        • Rondrit maken lukt niet
                          Rob Vonk
                          Rob Vonk
                          201
                        • Offline kaarten downloaden
                        • Missing option to avoid "unplaned" closed road
                          Banshees
                          Banshees
                        • GPX1.2 & Garmin Tread
                          Danny 1d
                          Danny 1d
                          445
