  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 10.0k Views 7 Watching
  • Guzt Guzt
    Using off line navigation or not, always switch off roaming in Switserland. They have their own telecom rules and are not part of the EU which implicates that the EU roaming agreements don't apply for them. As soon as your telephone makes contact to a Swiss telephone service, costs kick in. To avoid this, use a Swiss eSIM .
    https://saily.com/download-esim-app/
    @Guzt However, this is only partially true. For example, Deutsche Telekom's tariffs include roaming in Switzerland and the UK.
    I can't comment on other providers.
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
    • Guzt Guzt
      @Guzt I mentioned this before... That's not entirely true! There are Dutch providers that simply consider Switzerland an EU country. For example, with my Dutch mobile plan, I'm allowed to use 50GB per month from my Dutch data bundle in an EU country (including Switzerland). So you really need to check the terms and conditions of your provider in your own country!
      • Guzt
        Guzt
        Guzt
        My provider blocks Switzerland just to avoid the possible surprise. I have to activate it or buy a data plan for it. But then, Belgian telecom is so what the most expensive in the EU.
        So it is up to Adrian to check this with his telecom provider.
        • Guzt Guzt
          @Guzt said in MRA and tunnels:
          Time to shop elsewhere πŸ˜‰
          • nomko nomko
            Does offline navigation not solve this issue? Or are you even with offline navigation depending on a good/solid/working GPS connection?
            @Nomko-Nomden offline navigation depends also on good GPS receive. Means: you don't need roaming/eSIM for Internet connection. But in long tunnels, you will loose GPS - and if there is an exit inside the tunnel, you need to take- MyRoute-App may will not navigate you!
            • Herman Veldhuizen
              #19
              i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
              Guzzist TomOnTour 2 Replies Last reply
                @Herman-Veldhuizen ...then you are lucky.
                The reasons are:
                • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
                • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
                • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
                It depends on the tunnel operator.
                • Guzzist Guzzist
                  The reasons are:
                  #21
                  @Guzzist the fact that it worked in all tunnels made me think that HERE maybe has made an improvement (i assume a newer version of the sdk is used since I last tried it). The cursor followed the tunnel shape.
                  I will soon drive through the tunnel again in which I know MRA was struggling.
                  I dont think that I made any changes on my phone to settings to improve the gps accuracy.
                  • Garry Davis
                    Garry Davis
                    Garry Davis
                    Never knew about the beacons in tunnels or activation in settings. Just activated mine in Google maps. Thanks for that.
                    πŸ‘πŸοΈπŸ‘
                    • Herman Veldhuizen
                        TomOnTour
                        TomOnTour
                        TomOnTour
                        @Herman-Veldhuizen
                        I had exactly the same experience when I was in Norway last year. I also couldn't remember any problems in any oher tunnel I ever used: Neither in the alps, nor in the german tunnels like Elbtunnel.
                        Greetings
                        Thomas
                        MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
                        MRA Navigation Next (Lifetime Gold)
                        MRA Routeplanner NEXT beta (Lifetime early access)
                        TomOnTour
                        TomOnTour
                        Guzt
                        Guzt
                        Garry Davis
                        Garry Davis
                        Tony 13
                        Tony 13
                        Makro
                        Makro
                        • Sharing live location with friends on Android Auto problem
                        • Ability to hide all waypoints at once after planning?
                          BΓ© Jeuring
                          BΓ© Jeuring
                        • Next: Ich brauche Hilfe zu POI und Favoriten!
                        • Planner: Convert batches of shaping points into via points and vice versa
                        • How can I change colours in the route overview?
                          Parantapa
                          Parantapa
                        • Weather: rain colors
                        • Display street sign and name during navigation
                        • vanuit Bibliotheek nieuwe map aanmaken!
