  4. Problem with announcing via points
25 Posts 6 Posters 6.8k Views 3 Watching
  • Nick Carthew
    @Gerard-van-der-Veer Your original problem was that you could not hear the announcements, now you can - problem solved 😁
    • Gerard van der Veer
      Gerard van der Veer
      Gerard van der Veer
      Hi Nick, totally agree — really great!
      But I’m now wondering how it’s possible that I already hear the information at 2000 meters, even though I set a shaping point about 1000 meters before the via point.
      • Gerard van der Veer Gerard van der Veer
        @Gerard-van-der-Veer Yep, that’s a strange one. I must admit that it has been some time since I used this feature, and I do try to plan my routes accordingly, so it may have changed now. @Con-Hennekens is more up to date, he may be able to answer or offer a solution.
          Gerard van der Veer
          Gerard van der Veer
          Okay Rick, thanks again so much. Maybe others know how this exactly works.
          Talk to you sometime!
            @Nick-Carthew said in Problem with announcing via points:
            Well I am not so certain of that 😉
            @Gerard-van-der-Veer, Are you saying that you hear the name and/or note of a via point at 2000 mtrs, while there still is a shaping point in between at 500 mtrs? It is my understanding that audible notes should wait until they are next in line. That is, in a route navigated as route. It might be different (it likely is) for routes navigated as track. There is a technical reason for this assumption, but that is beyond the scope here. So my question to you is: do you have "navigate route as track enabled" by any chance, or are you navigating a route planned on a map other than here (those are navigated as track by default, even without the feature enabled).
              Gerard van der Veer
              Gerard van der Veer
              Hi Con-Hennekens, thanks for thinking along with us.
              I simply navigate using the Here map and select navigation as a route, not as a track. I created a test route with two via points and placed a shaping point at different distances before each via point. In all cases, I already received the via point information at 2000 meters. Strange.., very strange..
              • Marinus van Deudekom
                I wiil perform a test today and report back
                  Just did the test drive
                  Made a ROUTE and followed it. It contained 3 viapoints and 5 shapingpoints, start, in between and end.
                  The viapoint in the middle was announced accoring to the plan aprox. 2 km in advance.
                  I put 2 shapingpoint less than 2 km before the end viapoint.
                  At 2 km before the end, nothing was announced
                  at the last shapingpoint before the end viapoint aprox 600 meter before the end viapoint the end Viapoint was announced.
                  Maybe @Gerard-van-der-Veer did not change the text in the Viapoints that he used and therefore nothing was announced. It is mandatory that you change the text of a viapoint into something else nothing using numbers in it.
                  During my test everything when according the plan so no problems there
                  Have fun
                    Gerard van der Veer
                    Gerard van der Veer
                    I did some experimenting myself and went through all the settings again. I must have changed something along the way, because it’s working now!
                    I suspect — though I’m not completely sure — that the slider for “Use all route points” was set to the left. The strange thing is that this slider shows “Off” in both the left and right positions. I’m not entirely sure what its exact function is or whether it’s actually relevant in this case, but when riding a route now I can see the shaping points, which I couldn’t see before.
                    Long story short: I don’t know exactly what was wrong, but it’s working now.
                    Thanks again everyone for the tremendous help and for thinking along with me!
                    Nick Carthew Con Hennekens 2 Replies Last reply
                      @Gerard-van-der-Veer, I will repeat my earlier question: do you have "navigate route as track enabled" by any chance? (check at: Account-icon top right - Navigation settings (nearly at bottom) - Functional - Navigate routes as tracks (almost at bottom). Is that enabled or disabled?
                        Have fun
                        @Marinus-van-Deudekom, great test thanks. It would be interesting to repeat that test with "Navigate route as track" enabled. I suspect that in that case the outcome is like @Gerard-van-der-Veer experiences.
                          @Con-Hennekens I will do a similar test tonight as requested. Not the same route but with the same things in it
                            @Gerard-van-der-Veer said in Problem with announcing via points:
                            Use all waypoints is a setting associated with Navigate routes as tracks.
                            It shows both shaping points as well as via points when navigating a track and can only be selected if you have also selected Navigate routes as tracks.
                              If you mean that it is greyed out, you definitely have "Navigate route as track enabled". So you are riding a track after all... I am still not convinced that the announcements work like intended for a route, but if it is, that's very good to know.
                                Gerard van der Veer
                                Gerard van der Veer
                                I'll test that setting too, tomorrow and report back here.
                                  Second test tonight
                                  Using option ride route as a track
                                  The first viapoint without shapingpoints in 2 km. The viapoint was vallen out as expected.
                                  The end Viapoint with 2 shapingpoints in the 2 km before was never calédonien during the route. Just when ariving there it was called out. Just like you expected @Con-Hennekens
                                  So the conclusion is that @Gerard-van-der-Veer most likely drive his route as a track
                                  Gerard van der Veer
                                  Gerard van der Veer
                                  • Strange translation
                                  • Undo/Redo tool is hidden
                                  • Crazy routing
                                  • Shared toggle switch
