  4. Waypoints - copy request
13 Posts 7 Posters 3.5k Views 4 Watching
  • Jörgen Offline
    Jörgen Offline
    Exactly, place your last WP under favourites and it is available next day as startpoint.
    • Wallace Shackleton Wallace Shackleton
      Scenario.
      Planning a multi day trip. The route needs to be changed. A new stopping point is found but that new point needs to be the starting point for the following day.
      Being able to copy and paste the new waypoint into a new route would be a great help.
      The work around of copy the lat/long then go into the new route, paste it and rebuild the waypoint information.
      Guzzist Offline
      Guzzist Offline
      @Wallace-Shackleton not sure, if I understand correctly. But I agree: if you simply want to copy a routepoint from one route into another route - you may do it by copying the lat/long detail and search by it in the other route.
      But then, you get only this location for a (new) routepoint. But all the information from the first routepoint -
      • routepoint name
      • routepoint additional information
      • possible pictures
        will not be copied. And that's the matter, or?
        Scenario.
        Travellexxie Offline
        @Wallace-Shackleton you can do it the other way around: if you are planning a multi day trip, start to plan it as a whole route, because you know where you are going to. So set the end of each day as a waypoint and the engine is quickly enough to plan for you rapidlyy (I wouldn't suggest it with Baseccamp 🙈).
        If you have done this, open the toolkit, choose "split" and voila, your end of day 1 is the start of day 2, etc.
        MRA Lifetime Gold
        Guzzist 1 Reply Last reply
        • Travellexxie Travellexxie
          Guzzist Offline
          Guzzist Offline
          @Lex.Kloet.RX yes - but this is only possible, if you want to have the last routepoint from first day also as starting point in the second day.
          But if you simply want to copy "any" routepoint into "any" other route - then the "splitting idea" is not a solution 😉
          • Guzzist Guzzist
            @Guzzist that's the second sentence of what the topicstarter wrote 😉 "A new stopping point is found but that new point needs to be the starting point for the following day."
            MRA Lifetime Gold
              Guzzist Offline
              Guzzist Offline
              @Lex.Kloet.RX yes, I know - he mentioned first and second route...
              But he wrote also about "copy" and copy by using the lat/long info. And this can be used everywhere.
              I will not hijack this topic; may I should open another thread...
              • Jörgen Jörgen
                Hubert Thoring Online
                @Jörgen said in Waypoints - copy request:
                Learned something again... because the favorites are always available.
                But only the basic text under 1.) is taken over, where the street name is written, etc.
                The note is not saved in the favorite, just as an image is not transferred...
                iPad 9. Gen iOS 26.6.1/ iPhone 16e iOS 26.6.1 / Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                • paul69 Offline
                  paul69 Offline
                  Sometimes using your finish waypoint as the next day’s starting point can cause problems, I’ve learned this the hard way.
                  For example,
                  your final waypoint might be set on the road outside a hotel. That road could be one-way, while the hotel car park is actually behind the building, meaning you have to drive past the hotel and enter from another street.
                  If you then start the next day from the carpark using that same end waypoint as your starting point, the navigation may send you all the way around the one-way system just to get back to waypoint #1 outside the hotel.
                  Hope that makes sense and helps someone avoid the same issue 👍
                  K1600 GTL
                  Oukitel RT3
                  iPhone 13 Pro, carpuride 702b
                  • Hubert Thoring Online
                    A starting point should always be about 200-400m from the hotel in the direction of travel and can be reached safely 😉🍀
                    paul69 1 Reply Last reply
                      paul69 Offline
                      paul69 Offline
                      @Hubert-Thoring said in Waypoints - copy request:
                      yes, i wrote words to that effect in post #2 of this thread.
                      K1600 GTL
                      Oukitel RT3
                      Wallace Shackleton
                      Wallace Shackleton
                      • Is there a way to put a Home button in the program
                      • Google maps and Streetview
                        Stevedo 6 0
                        Stevedo 6 0
                        601
                        655
                      • Is there a way to re-order the routes in your routes folder?
                      • MRA 5.2.2 (489) Route time is calculated incorrectly /// Strecken Zeit wird falsch berechnet
                      • It was not possible to find a correct route to Wheels Through Time
                        266
                      • Route doesn’t recalculate to my destination
                      • MRA In the BMW - Cradel vertically and horizontally /// MRA im BMW - Cradel senkrecht und waagerecht nutzen
