  4. Problema Car play
Problema Car play
45 Posts 8 Posters 18.2k Views 5 Watching
  • Òscar Òscar
    @Con-Hennekens Using a cable on a motorcycle is completely absurd. I won't continue this pointless debate.
    @b0hd1, Who is being the negative one here... 🤣
    Did I say somewhere that you should use a cabled connection on a bike? Don't think so... I said most of my testing was done IN MY CAR by cabled connection. FYI I have tried the wireles dingle also: rock solid... I just wanted t rule out a possible influence in stability from the dongle. It seems not to exist (in my case). But yeah, like you said, a very pointless debate you made from it...
    • Lluis Arasanz
      I tested cabled and Wired with dongle, IOS 26.2 and Android 14.
      Both with different errors, and with time to do a well test 'cause I was not driving, so with time to do testing.
      IOS is more Stable than Android, but also has some bugs and workarounds to implement.
      And here, we are discussing if this errors are a real problem or not, and gouping our voice to standup a flag for development. We're no telling that App is a bad one, or worse than any other; I'm a Lifetime of Planner and also Next, so my first interest is to have a good, solid-as-a-rock, fast and stable app to use every day.
      Development priority is not my objective, only to help to increase task list to arrive to good port.
      Regards,
      • BMW F750GS
        @Adrian-Avram said in Problema Car play:
        The developers seem more focused on adding new features than on fixing this fundamental problem.
        I'd like to add that "this problem" is fundamental for less people each version. The amount of people having problems has decreased drastically over the last few versions, so in all honesty you cannot claim that nothing has been done about it.
        I’m not willing to risk mounting a phone worth over €1,000 on the handlebars just to use MyRoute App.
        No, I would certainly not advise that, I do not even put my 2 years old €600 phone on my handlebar. Instead I buy a fully rugged phone for €250 instead of some twice as expensive AA/CP device 😉 and be done with it.
        @Con-Hennekens said in Problema Car play:
        Just because you don’t use Android Auto doesn’t mean others shouldn’t. For those of us who do use it, this is still a real issue, it still is "a problem" !
        Yes, it has—because many users have migrated to other apps (OsmAnd, Calimoto, Kurviger, TomTom), which work perfectly with Android Auto, without excuses.
        Thats not a sollution for me, and others, to buy and carry around another device when you can connect wirelessly to a factory built in display (Africa Twin) !!
        Adrian
        • Òscar Òscar
          @Con-Hennekens Whether you want to use a smartphone instead of CarPlay is your decision, not anyone else's. I use a €1000 tablet and a €700 CarPlay system. It's my choice. I just hope both systems work properly, not that someone tells me which one to use.
          We would appreciate positive contributions, not contributions that constantly try to cover up mistakes. Thank you.
          @b0hd1 said in Problema Car play:
          Exactly my point. I don’t understand why people on this forum are trying to cover up issues instead of helping to identify the root cause—just because they don’t use the app with Android Auto / CarPlay. That doesn’t help users or the developers.
          Adrian
          • Lluis Arasanz Lluis Arasanz
            Regards,
            @Lluis-Arasanz said in Problema Car play:
            Same here !
            Adrian
            • Adrian Avram Adrian Avram
              @Adrian-Avram:
              • I do use Android Auto
              • I do understand that you want to use your built in AA/CP gadget (I do too, in my car)
              • I have been extensively testing that the past half year
              • I am quite confident that I helped devs more on this issue than you did
              • your claim abou migrating is BS
              • I am not the negative one here, you seem to be though
              Let's rest this pointless mud-throwing here, shall we?
                In another thread I was reminded on a simple trick to rule out problems with AA/CP built-in GPS units. It might be worth to see what it does in your specific problem cases @Lluis-Arasanz, @b0hd1, @Adrian-Avram and possibly others
                In Android system settings goto Apps - All Apps - search for Android Auto - tap Android Auto - Permissions - tap Location - Disable this permission - go back yo your main screen - force close the MRA app and reopen it
                There is most likely a similar option for iPhones and CarPlay, but I am not familiar with those. I know this sounds counterintuitive, but bear with me. The idea behind this, is that Android Auto loses it's permission to use the AA/CP built in GPS, the MRA app will automatically fall back to using your phone's GPS. Let's see what it does after this, if no improvement, reverse the setting. Personally I do this, because my Ford Sync3 headend does not communicate speed information correctly. We have seen all kinds of crazy stuff happening due to faulty communication by some AA/CP devices, up to driving backwards completely. And yes, often other apps work correctly, but they have hundreds of developers hunting for workarounds. MRA does not 😉
                Lluis Arasanz Òscar 2 Replies Last reply
                  Take for sure I'll test this.
                  But, have you noted that this reply is someone we expect to have?
                  This one, even in case not working for us,
                  • explain how AA uses Location,
                  • address a workaround for AA Aplications
                  • and why, even if this workarond sounds "bad", must be taken into account.
                  This kind of answers is what I expect from an Alpha Tester. Great!
                  Regards!!!
                  • BMW F750GS
                    Òscar
                    Òscar
                    Òscar
                    @Con-Hennekens Yes sir!! Now that's more like it!!! This is what I call trying to provide solutions and making valuable contributions. Bravo. I'll try it this afternoon. I have a trip of just over an hour and I'll be able to run several tests. I'll let you know the results.
                    Thanks again.
                    • https://t.me/MRa_by_b0hd1
                    • YouTube: @demco17
                      Thanks guys, mind you I have never intended a mud sling conversation. I think I am contributing positively to this community an almost insane amount. Then when someone claims me to be negative or narrowminded, I simply think that's not true and can get a little defensive about it. Please keep in mind that all alpha testers are volunteers and get nothing out of it, except great appreciation from MRA, it's devs and hopefully from the community.
                      I am curious to the outcome of your testing.
                        Òscar
                        Òscar
                        Òscar
                        @Con-Hennekens I think I've also put you on the defensive, and I apologize. Look at my signature. For over five years, I've had a Telegram group dedicated exclusively to MRA with more than 500 members, in addition to over 1,000 followers on the MRA web group. So we're all in the same boat!
                        • YouTube: @demco17
                        • Òscar Òscar
                          We certainly are! 😉
                          • Rob Verhoeff
                            Managed to get my hands on a Bluetooth dongle (Buddy Play 2) today. I’ve pushed the app to its limits wherever I could, and while driving a route and an A2B, I didn’t encounter any issues.
                            Òscar 1 Reply Last reply
                              Òscar
                              Òscar
                              Òscar
                              wrote on last edited by Òscar
                              #35
                              @Rob-Verhoeff You're so lucky. Others with air conditioning are still having problems. I've attached a photo from right now with my car stopped. Look at the speed it's showing. The screen is completely frozen...
                              • YouTube: @demco17
                                Òscar
                                Òscar
                                Òscar
                                #36
                                @Con-Hennekens It didn't work. It keeps freezing. 😑 https://youtu.be/4SKGopQtn94?si=XQuD7SNHonuQv_rq
                                • YouTube: @demco17
                                • Òscar Òscar
                                  @b0hd1 I don’t quite understand what air conditioning has to do with how the app works... Perhaps you could write down the exact steps, point by point, that lead to your screen freezing. I’ll then try to reproduce the issue.
                                  I’m unable to play the video you posted...
                                    Òscar
                                    Òscar
                                    Òscar
                                    #38
                                    @Rob-Verhoeff Hehe. The spell checker changed AA (Android Auto) to air conditioning... In the video, you can see MRa frozen and Osmand working. It's that simple.
                                    For my part, I'm refraining from further testing and debate. It's 100% clear that MRA doesn't work reliably on Android Auto. We'll wait for the development team to find a solution.
                                    Please @Corjan-Meijerink
                                    • YouTube: @demco17
                                    • Òscar Òscar
                                      @b0hd1 let me say that I truely believe that in YOUR case MRA doesn’t work perfectie with YOUR AA device. We’ve that in more combinations of devices. Your statement that MRA is 100% not reliable is absolutely not correct.
                                      In MY experiance it’s 99,5% reliable. The half % comming from the one update introducing the Free ride mode witch caused my AA to freeze up completely, witch Corjan fixed that same day.
                                      -2
                                        @Marinus-van-Deudekom said in Problema Car play:
                                        @Marinus-van-Deudekom I can confirm also that MRA doesn't work on two of my devices with my CP/AA device.
                                        Perhaps, this 99,5% is not so high as you expects.
                                        • BMW F750GS
                                          Òscar
                                          Òscar
                                          Òscar
                                          #41
                                          @Marinus-van-Deudekom I know exactly what I'm saying. It doesn't work reliably with wireless Android Auto. 100% demonstrable, as many times as necessary, on different devices. As I said, I won't do any more testing or engage in any more debate. I'm available to @Corjan-Meijerink for any testing he needs, just as I and my group of over 1000 users have done for the past 5 years. Quietly, but with a lot of hard work. Regards.
                                          • YouTube: @demco17
                                          Òscar
                                          Òscar
                                          Jan 50
                                          Jan 50
                                          Vincenzo Attardo
                                          Vincenzo Attardo
                                          • Kaart niet zichtbaar
                                            209
                                            Bé Jeuring
                                            Bé Jeuring
                                            22
                                            41
                                            354
                                          • Xpert overlay not clear
                                          • Google maps
                                            Ed Bos 0
                                            Ed Bos 0
                                            206
                                          • Navigation Next op telefoon wel naar v6 maar Android 14 systeem op motor niet
                                            Jaap van Maanen
                                            Jaap van Maanen
                                            142
                                            Corrado Miniati 0
                                            Corrado Miniati 0
                                            286
