  4. Absurd detours on the highway maps HERE
22 Posts 6 Posters 6.5k Views 4 Watching
  • Aiello antonino
    Non così allora per quale motivo a me la fa vedere così...vedrò dal PC, adesso sono da iPdad,uso sempre questo per tutto
    • Travellexxie
      Always put waypoints on the grey line (route). If your destiny is not nearby the route, use a POI instead (waypoint 3 hotel). Waypoints 8, 15, 16 and 18 are also too far from the line.
      Like Rob wrote, I also don't see any strange behaviour of the route.
      MRA Lifetime Gold
      • Aiello antonino
        Yes, I knew about the points far from the route line, I had placed them there to remind myself that I have to place points of interest, now I have fixed them, but the problem with the STANDARD maps does not change, I also tried from PC and the problem occurs there too...
        • Travellexxie
          What do you mean by "standard maps" and with what do you want to navigate? The app something else?
          MRA Lifetime Gold
          • Aiello antonino
            I navigate with the app, by maps I mean the STANDARD calculation method...as in the photo
              @Aiello-antonino Change your planning map. The OpenStreetMap does not calculate long distances. Or split your route into shorter, daily routes.
              • Aiello antonino
                #17
                I always use HERE, I accidentally checked the standards and noticed this…But you said you tried and show the route…
                • Travellexxie
                  Ah ok, for your convenience use the HERE map. OSM can't, as Nick wrote, process such long routes. But even if you compare the route with TT, you will see differences. This is just an example.
                  MRA Lifetime Gold
                  • Aiello antonino
                    #19
                    Yes, I know that, I know how it works, but using HERE maps and the navigation app I never use TomTom or standard maps... while I like to keep Google, Michelin and even OSM as overlays... it depends on what I need to do and see along the route...
                    • Hubert Thoring
                      #20
                      The route is not displayed with OSM calculation because it is far too long, but it works with HERE...
                      • Hubert Thoring
                        As some have already mentioned, 27 waypoints for approximately 5500 km is very few to have a clear route. As Rob already wrote, it's better to plan day trips.
                        Avoidance routes should also be used as long as it makes sense.
                        • Aiello antonino
                          Yes, thank you! I didn't know that OSM didn't support long distances...
                            2.1k
                            1.9k
                          • Elektrisch voertuig
                            694
                          • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
                          • MyRoute-app wedding
                            28
                            40
                            10.4k
                          • MRA V6.0.0 (515) The viewfinder is somehow inaccurate and does not find it which is not a problem in the WebPlaner./// Suchfunktion ungenau - findet es nicht
                          • New beta! 6.0.0 (514)
                            32
                            383
