  4. Absurd detours on the highway maps HERE
22 Posts 6 Posters 7.3k Views 4 Watching
    @Aiello-antonino Can you share your route please?
    @Rob-Verhoeff
    https://www.myrouteapp.com/it/social/route/12559350?mode=share
      @Rob-Verhoeff
      @Aiello-antonino To be completely honest… putting together a route of over 5500 km this way is asking for trouble. It’s nice as an overall overview, but hardly suitable for actual navigation! I suggest splitting the route into daily trips. After that, you can optionally merge the individual day trips — each in a different color — to get a complete overview of your route. There’s really no way to make any meaningful comments about it otherwise!
      By the way, it does show as a complete route when I view your route!
      • Aiello antonino
        Yes, at the moment it is the complete route, I will divide it when I have defined everything that interests me, but I understood what the "problem" is due to, the closures that the HERE maps have, TOMTOM does not have these closures, but as written, the problem that happens is that if you set the calculation method to STANDARD, the itinerary disappears, do you say it is due to the length of the itinerary? Photos 5-6
          @Aiello-antonino said in Absurd detours on the highway maps HERE:
          Perhaps, although I do see a route line — unlike in the photos you posted.
          • Aiello antonino
            Non così allora per quale motivo a me la fa vedere così...vedrò dal PC, adesso sono da iPdad,uso sempre questo per tutto
            • Travellexxie
              Always put waypoints on the grey line (route). If your destiny is not nearby the route, use a POI instead (waypoint 3 hotel). Waypoints 8, 15, 16 and 18 are also too far from the line.
              Like Rob wrote, I also don't see any strange behaviour of the route.
              MRA Lifetime Gold
              • Aiello antonino
                Yes, I knew about the points far from the route line, I had placed them there to remind myself that I have to place points of interest, now I have fixed them, but the problem with the STANDARD maps does not change, I also tried from PC and the problem occurs there too...
                • Travellexxie
                  What do you mean by "standard maps" and with what do you want to navigate? The app something else?
                  MRA Lifetime Gold
                  • Aiello antonino
                    I navigate with the app, by maps I mean the STANDARD calculation method...as in the photo
                      @Aiello-antonino Change your planning map. The OpenStreetMap does not calculate long distances. Or split your route into shorter, daily routes.
                      • Aiello antonino
                        #17
                        I always use HERE, I accidentally checked the standards and noticed this…But you said you tried and show the route…
                        • Travellexxie
                          Ah ok, for your convenience use the HERE map. OSM can't, as Nick wrote, process such long routes. But even if you compare the route with TT, you will see differences. This is just an example.
                          MRA Lifetime Gold
                          • Aiello antonino
                            #19
                            Yes, I know that, I know how it works, but using HERE maps and the navigation app I never use TomTom or standard maps... while I like to keep Google, Michelin and even OSM as overlays... it depends on what I need to do and see along the route...
                            • Hubert Thoring
                              #20
                              The route is not displayed with OSM calculation because it is far too long, but it works with HERE...
                              • Hubert Thoring
                                As some have already mentioned, 27 waypoints for approximately 5500 km is very few to have a clear route. As Rob already wrote, it's better to plan day trips.
                                Avoidance routes should also be used as long as it makes sense.
                                • Aiello antonino
                                  Yes, thank you! I didn't know that OSM didn't support long distances...
                                  • MyRoute-app offline
                                    55.4k
                                  • Control screen font size
                                  • Map colours and side roads
                                  • MRA Studio export speed
