  4. Absurd detours on the highway maps HERE
22 Posts 6 Posters 4.6k Views 4 Watching
  • Aiello antoninoundefined Offline
    Yes, at the moment it is the complete route, I will divide it when I have defined everything that interests me, but I understood what the "problem" is due to, the closures that the HERE maps have, TOMTOM does not have these closures, but as written, the problem that happens is that if you set the calculation method to STANDARD, the itinerary disappears, do you say it is due to the length of the itinerary? Photos 5-6
    • Aiello antoninoundefined Aiello antonino
      Rob Verhoeffundefined Offline
      @Aiello-antonino said in Absurd detours on the highway maps HERE:
      Perhaps, although I do see a route line — unlike in the photos you posted.
        Non così allora per quale motivo a me la fa vedere così...vedrò dal PC, adesso sono da iPdad,uso sempre questo per tutto
          Always put waypoints on the grey line (route). If your destiny is not nearby the route, use a POI instead (waypoint 3 hotel). Waypoints 8, 15, 16 and 18 are also too far from the line.
          Like Rob wrote, I also don't see any strange behaviour of the route.
          MRA Lifetime Gold
            Yes, I knew about the points far from the route line, I had placed them there to remind myself that I have to place points of interest, now I have fixed them, but the problem with the STANDARD maps does not change, I also tried from PC and the problem occurs there too...
              What do you mean by "standard maps" and with what do you want to navigate? The app something else?
              MRA Lifetime Gold
                I navigate with the app, by maps I mean the STANDARD calculation method...as in the photo
                  Nick Carthewundefined Offline
                  @Aiello-antonino Change your planning map. The OpenStreetMap does not calculate long distances. Or split your route into shorter, daily routes.
                    #17
                    I always use HERE, I accidentally checked the standards and noticed this…But you said you tried and show the route…
                      Ah ok, for your convenience use the HERE map. OSM can't, as Nick wrote, process such long routes. But even if you compare the route with TT, you will see differences. This is just an example.
                      MRA Lifetime Gold
                        #19
                        Yes, I know that, I know how it works, but using HERE maps and the navigation app I never use TomTom or standard maps... while I like to keep Google, Michelin and even OSM as overlays... it depends on what I need to do and see along the route...
                          #20
                          The route is not displayed with OSM calculation because it is far too long, but it works with HERE...
                            As some have already mentioned, 27 waypoints for approximately 5500 km is very few to have a clear route. As Rob already wrote, it's better to plan day trips.
                            Avoidance routes should also be used as long as it makes sense.
                              Yes, thank you! I didn't know that OSM didn't support long distances...
                              • Manual Zoom
                                36
                                943
                                Koen Vandecauter 0undefined
                                Koen Vandecauter 0
                              • Back from vacation
                                13
                                229
                              • WunderLinQ: BMW Wonderwheel to the left for a long time does not work
                                Mopetenpitundefined
                                Mopetenpit
                                1.3k
                              • Wunderlinq mive keft
                              • Hello, i want to make a trip to the Dolomieten (cortina )from Halle 1500(Belgium) in about 3 days. came somebody tell me a nice route or what i must avoid?Thanks
                              • fuel stops when using track navigation
