  4. WAYPOINT Announcements
4 Posts 4 Posters 484 Views 2 Watching
  • Routemasterundefined Offline
    Routemaster
    I like the fact that waypoints can be changed to allow spoken notifications, however after I have changed the waypoint to what i wish to be spoken it is announced immediately after a waypoint I have just passed and not close to when I actually get near or approach it? only the number of the waypoint is announced? considering this could be many miles later it seems pointless,,, can it be somehow changed so that the desired announcement happens when near or at the actual waypoint?
    cheersπŸ‘
    Nick Carthewundefined Con Hennekensundefined Brian McGundefined 3 Replies Last reply
    • Routemasterundefined Routemaster
      cheersπŸ‘
      Nick Carthewundefined Offline
      @Routemaster
      Information added to notes in shaping points is announced at 750 metres before reaching the shaping point. Via point notes are announced at 2 kilometres before you reach the via point.
        cheersπŸ‘
        @Routemaster, What @Nick-Carthew says, plus: an extra waypoint within those distance limits will hold it up until you pass it. You found out that already πŸ˜‰
          cheersπŸ‘
          Brian McGundefined Offline
          @Routemaster I agree with you 100% but the devs & MRA Illuminati think otherwise so don't hold your breath for any changes
          Previous forum threads on this topic & info on the secret "contains a number" filter
          https://forum.myrouteapp.com/post/49593
          https://forum.myrouteapp.com/post/51050
          As I have said many times, the whole idea of announcements at fixed distances IMO is just totally absurd, the announcements should actually be calculated by estimated time to point, the system has speed & distance so that is a trivial calculation (& don't say speed varies, you can average or extrapolate)
          e.g. traveling at 10km an hour with the current setup I get a Via point announcement at 2km which is 12 minutes before I arrive at the Via point, you can pick faster speeds but it is still ludicrous, you have to be doing > 120km/hr for the announcement to be heard at a reasonable interval before the point
          & yes the superfluous pretty useless "you have reached waypoint numberX" why this announcement can't just be modified to actually announce the waypoint name
          IMO these changes would make MRA better
          Normaly navigate Routes in Offline mode with Offline Maps
          Routemaster
          • Track, route als track slaat lus over
            AWDC LAOundefined
            1.7k
          • In eens verdwenen mogelijkheid om 3 apparaten te gebruiken als Gold member?
            AWDC LAOundefined
            576
          • Snelheidsweergave in spit screen modus carplay
            Remco vd P.undefined
            Remco vd P.
          • Probleem met ANDROID in de wagen.
            Rob Verhoeffundefined
          • Here map errors
            Tom Grzelinskiundefined
            Tom Grzelinski
            1.2k
          • Siri gebruiken met CarPlay
            white.mouseundefined
