  4. Account Units not honoured when displaying Tracklog info #bug
24 Posts 8 Posters 7.3k Views 4 Watching
  • Andy W
    Andy W
    Andy W
    I have the Units in my account profile set to Imperial (mi, GB):
    When I display a Tracklog using the website, the minimum and maximum height use Imperial units:
    However, the app displays the same Tracklog height details in Metric:
    Andy
    • Andy W Andy W
      Andy
      @Andy-W No bug! The answer is as logical as it is simple: both the website (Routeplanner) and the app have a settings menu. According to the images you attached, you have the distance unit set to metric in the app and to imperial (GB or US) in the Routeplanner.
      Andy W 1 Reply Last reply
        @nick-carthew so would it make sense that imperial GB does show metric for altitude?
        But then @Andy-W would expect feet for altitude when using imperial US.
        I have no clue here what is expected cause even the countries using imperial aren’t consistent. It’s always a 9mm gun but never a 0.3 inch gun πŸ˜‰
          Andy W
          Andy W
          Andy W
          @Rob-Verhoeff said in Account Units not honoured when displaying Tracklog info #bug:
          No. The settings are the same in both and I would expect them to be as it is a single account for MRA.
          Andy
          • Andy W Andy W
            Andy
            @Andy-W Okay, didn't expect that. I can only reproduce this when settings are different... or am I overlooking something?
              @Rob-Verhoeff altitudes within the app are always displayed in meters it seems πŸ™‚
                @Corjan-Meijerink Yes, I see it now. Definitely not something I would have noticed like that. I had only changed the notation in the planner and then saw that the app was showing meters. But apparently, it is a bug. πŸ˜‰
                @Andy-W sorry about the misunderstanding πŸ˜‡
                  For me it’s just not always understanding when imperial uses what unit πŸ˜†
                  That’s why I asked @nick-carthew on the GB view. If the consensus is indeed that US imperial always want feet for altitude, sure thing πŸ™‚
                    I would say it's about time they get used to metric, like we all are used to English. Do something in return! πŸ˜‰
                    Brian McG 1 Reply Last reply
                      @Con-Hennekens sorry we are not adopting the kilometer, unless of course europe is prepared to start driving on the left/correct side of the road πŸ˜‚
                      if it is a binary choice, imperial or metric, then IMO the imperial choice should result in the altitude being in feet
                      it makes no sense to choose imperial & then find the result is in meters
                      the alternative is to make it a non-binary choice by allowing the units for speed, distance & altitude to be chosen independently but this probably will be at the expense of complicating the UI & backend code
                        @Corjan-Meijerink The UK use whatever measurements suit us best 😊
                        In the UK feet and inches are used for height measurements and yards and miles are used for distance.
                        The US use feet and inches for height and feet and miles for distance.
                          So changing altitude readings to feet it is then πŸ™‚
                            @Corjan-Meijerink said in Account Units not honoured when displaying Tracklog info #bug:
                            Yes please.
                              Fixed in the next update πŸ™‚
                              • ErikMatthezing
                                ErikMatthezing
                                ErikMatthezing
                                It would be best if the whole world would embrace the Metric system, much easier in every way. Especially for programmers πŸ™‚
                                • ErikMatthezing ErikMatthezing
                                  @ErikMatthezing, they don't know it yet, but they will in the end πŸ˜‰
                                  You see that most new technical fields metric is the norm already in the US also.
                                  UK I don't know really, maybe they are more stubborn then others πŸ˜‰
                                  (of course all this is meant humoristically!)
                                    @Con-Hennekens said in [Account Units not honoured when displaying Tracklog info #bug]
                                    All you foreigners will be dreaming in English and driving on the correct side of the road before we drop our imperial system. It’s what makes us unique. πŸ˜‰
                                    12 inches =0.305 metres or 1 foot
                                    36 inches =0.914 metres or 1 yard
                                    1760 yards =1,609.344 metres or 1 mile
                                    It’s simple, no need for decimal points 😊
                                    MotoCon Andy W Marinus van Deudekom 3 Replies Last reply
                                      @Nick-Carthew, haha... you cannot even get the . and , right... πŸ˜‰
                                        Andy W
                                        Andy W
                                        Andy W
                                        @Nick-Carthew said in Account Units not honoured when displaying Tracklog info #bug:
                                        There are a few more essential elements to the imperial system that everyone should understand 😁
                                        https://www.youtube.com/watch?v=r7x-RGfd0Yk
                                          @Nick-Carthew there's a reason why it's called driving on the right side of the road 🀣
                                          ErikMatthezing
                                          ErikMatthezing
                                          Andy W
                                          Andy W
                                          • MyRoute-app offline
                                            55.4k
                                          • Control screen font size
                                          • MRA Studio export speed
                                            Tegel Werner
                                            Tegel Werner
