  4. Safety Tutor
Safety Tutor
20 Posts 10 Posters 6.1k Views 4 Watching
  • Marco Strani Offline
    Marco Strani
    The app is able to notify and show speedcams. What about Speed Tutor? It would be important to highlight when driving in a road section under the control of Speed Tutor, i.e. with a blinking ST (or similar text) on the screen
    Con Hennekens Nick Carthew 2 Replies Last reply
    • Marco Strani Marco Strani
      @Marco-Strani, I suspect you are talking about trajectory speed control?
      Marco Strani 1 Reply Last reply
      • Tony 13 Offline
        Tony 13 Offline
        Tony 13
        not heard of either
          Nick Carthew Offline
          @Marco-Strani If you go to Navigation settings > Audio > Speed warnings and select All you will hear a warning when you go faster than the speed limit of the road that you are travelling on.
            Marco Strani
            @Con-Hennekens said in Safety Tutor:
            I'm talking about a a fairly common system on highways in Italy based on calculating the average speed over a stretch of road of a few kilometers. If the calculated average speed is higher than the limit, you'll be fined.
            Travellexxie Con Hennekens martin-phogel.de 3 Replies Last reply
              Marco Strani
              @Nick-Carthew said in Safety Tutor:
              I know the safest way of driving is to respect the limits 😉 but, as there is a way to know where speed cams are, I was wondering is there's a similar notification for this further speed check system
                Travellexxie Offline
                @Marco-Strani why do you need an app, to drive safely? 🤷🏻
                MRA Lifetime Gold
                • Travellexxie Travellexxie
                  Marco Strani
                  @Lex.Kloet.RX why do navigation apps notify speedcam?
                    @Marco-Strani I use neither, because in Germany (where I live) it is not permitted and I am used to ride without any warning. So, I drive in any vehicle (cabrio, camper, motorcycle) according to what the road signs indicate. They are there with a purpose.
                    MRA Lifetime Gold
                      @Marco-Strani said in Safety Tutor:
                      Yeah, that's called trajectory speed cam. As far as I know they are mentioned in the app, as far as they are known in the HERE map data.
                        martin-phogel.de Offline
                        martin-phogel.de
                        @Marco-Strani
                        I was in the Czech Republic a few months ago, where the tutor system (or something similar?) is also used, and I received a warning about it in MRA.
                        So it's quite possible that you'll receive these warnings in Italy too.
                          Marco Strani
                          thanks Martin, did you receive a warning only when entering the monitored section or during the whole section, or were you warned also when exiting it?
                            martin-phogel.de
                            @Marco-Strani
                            If I remember correctly, there was a warning at the beginning of the section and then a display during the section (remaining distance) and the measured average speed. But I'm not entirely sure anymore. Can't you just try it out?
                            • Alex reds Offline
                              Alex reds Offline
                              Alex reds
                              Hi Marco, with the MRA Navigation app you can be alerted about your speed compared to the speed limit, and you can also get warnings about speed cameras. However, the app doesn’t provide notifications for average speed check systems (tutors) — especially the new ones recently installed on some Italian highways.
                              Currently, only a few navigation apps warn you when you enter a tutor zone, but they offer far fewer navigation features overall. So, it’s better to stay cautious — driving a bit slower lets you enjoy the trip and the scenery much more.
                              • Alex reds Alex reds
                                @Alex-reds The app does warn you when you are in an ‘Average speed zone’.
                                richtea999 1 Reply Last reply
                                • Hubert Thoring Offline
                                  In Norway, the warning system has always worked very well!
                                  iPad 9. Gen iOS 26.6/ iPhone 16e iOS 26.6/ Navi iPhone Xr iOS 18.7.9 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                                  • Erdna Offline
                                    Erdna Offline
                                    Erdna
                                    I remember several occasions in Italy, when I was warned about Tutor zones. As often, Here map quality is the "issue". If nobody notifies about speed traps, etc., it won´t be available in map data.
                                      Marco Strani
                                      wrote on last edited by Marco Strani
                                      thanks, I will check at the first opportunity
                                        Marco Strani
                                        #19
                                        Yesterday I had the chance to check how the app behaves in this case.
                                        When approaching a Tutor zone, the app informs about it starting from 300 meters then, when entering the zone, a message similar to "Average speed check" stays on the screen (you can close it). Finally, when approaching the end of the zone, it informs starting from 800 meters, and decrementing the distance until the end, with a message similar to "Average speed check for XXX meters". The popup does not close automatically once you exit the zone and needs to be explicitly closed.
                                        While this is positively answering my initial question, I think that it would be better to inform earlier the start than the end of the zones: I'm generally not interested in driving faster than allowed but in being sure I am not doing it expecially when I am monitored
                                          richtea999 Offline
                                          richtea999 Offline
                                          Being very pedantic:
                                          The app does warn you when it has the data to know you are in an ‘Average speed zone’.
                                          It's very useful, but it can be out of date, have errors, etc, and it's up to you to keep your eyes peeled and ride to the road signs.
                                          Cameras are unforgiving. Except in the UK where you have a 10% + 1 mph leeway (as of right now - Nov 2025):
                                          https://www.met.police.uk/foi-ai/metropolitan-police/disclosure-2024/april-2024/speed-cameras-thresholds/
                                          Erdna
                                          Erdna
                                          Tony 13
                                          Tony 13
                                          Marco Strani
                                          Marco Strani
                                          martin-phogel.de
                                          martin-phogel.de
                                          Alex reds
                                          Alex reds
                                            1.8k
                                            50
                                            6.5k
                                          • New update 5.2.1
                                            16
                                            24
                                            1.1k
                                            16.4k
                                          • die selbe Route/Strecke zurückfahren, wie vorgehen bei Generierung der Navi Daten
