  4. Export Connector to Zumo XT not working MacOS 26
10 Posts 6 Posters 3.0k Views 3 Watching
  • Ron Z
    Ron Z
    Ron Z
    I have my XT updated to the latest firmware and maps. My Mac is running macOS Tahoe 26.0. I have no other apps open that is accessing the XT. From the Export menu I select "Garmin new (GPX 1.1) for the device. And when I select Export to device, I get this message:
    7530a6ed-27af-485f-bd76-dd269c7ddff8-Screenshot 2025-09-20 at 4.32.13 PM.png
    Any ideas on how to fix this issue? I know I can use the Drive app on my iPhone, but I'd like to use the Export option on the created route.
    2009 BMW K1300GT
    Garmin zümo XT
    2023 BMW R18 Transcontinental
    • Reinhard-32
      The Connector extension does not work with Mac OS and Android-based devices such as the ZumoXT.
      I use my mobile phone with MRA Next and the Garmin Drive app for this purpose.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      • Nick Carthew
        As @Reinhard-32 has said, the Garmin XT has an Android operating system therefore your Mac does not recognise it when it is connected with the MRA Connector. You need to install a small piece of software to enable your Mac to see Android devices. The software used to be called Android File Transfer but I’m not sure if this is still available. It would be helpful if other Mac could comment on this topic.
        • Travellexxie
          It could be a software problem, as described before, but you have also to remove any sd-card out of your XT. Otherwise, it won't work.
          MRA Lifetime Gold
            Rob Veerman
            Rob Veerman
            Rob Veerman
            @Nick-Carthew Nowadays I use OpenMTP instead of Android File Transfer
            • Mzokk
              I also have an XT and use the Garmin Drive app on my phone to transfer routes to the XT.
              • Rob Veerman Rob Veerman
                @Rob-Veerman said in Export Connector to Zumo XT not working MacOS 26:
                Thanks @Rob-Veerman. After downloading it to your Mac, does it just sit in the background and recognise the XT when you connect?
                  Rob Veerman
                  Rob Veerman
                  Rob Veerman
                  @Nick-Carthew When you connect your Garmin device to the Mac and MTPOpen is opened you can use it as an oldfashioned Windows Commander and transfer files. In my case I also use a hub where I connect the Garmin XT to. Reason for this is that my MacBook Air only has an USB C connection.
                  • Ron Z
                    Ron Z
                    Ron Z
                    So with one these Android apps installed and open/running, will the MRA Connector work to export GPX files to the zumo XT?
                    2009 BMW K1300GT
                    Garmin zümo XT
                    • Ron Z Ron Z
                      Rob Veerman
                      Rob Veerman
                      Rob Veerman
                      wrote on last edited by Rob Veerman
                      @Ron-Z No, I suppose the Connector will not perform that trick. Just download the GPX and transfer it to the connected Garmin XT by using OpenMTP. There is alternative software too, but this one is free.
                      Normally I always use Garmin Drive on my iPhone to transfer the GPX wirelessly from the MRA-app to the XT.
                      Rob Veerman
                      Rob Veerman
                      Ron Z
                      Ron Z
                        2.2k
                        1.9k
                      • Elektrisch voertuig
                        694
                      • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
                      • MyRoute-app wedding
                        28
                        40
                        10.4k
                      • MRA V6.0.0 (515) The viewfinder is somehow inaccurate and does not find it which is not a problem in the WebPlaner./// Suchfunktion ungenau - findet es nicht
                      • New beta! 6.0.0 (514)
                        32
                        383
