  3. [App] Announcements
  4. New update! (4.4.0)
New update! (4.4.0)
19 Posts 14 Posters 6.0k Views 5 Watching
  • C.A. Kielenundefined C.A. Kielen
    I use the app every day during my current 4-month trip. Last month in Iraq, I put the phone in the driving wind to cool it down. As soon as I arrived in a city with the usual congested traffic, the phone overheated and started giving a less and less clear picture until it stopped completely. Just when you need it the most. So I am very happy that the problem is found and my phone no longer overheats. To prevent overheating it also helps a little if you stop charging the battery.
    C.A. Kielenundefined Offline
    C.A. Kielen
    Drove all day today. After 2 hours of driving 35% battery used. That is real progress. Phone stayed cool all day.
    • Luk4s7undefined Offline
      Luk4s7
      I posted my last weekend issues with app here https://forum.myrouteapp.com/post/67675
      In short: still "eats-up" the route and crashes (after eating enough) 😉 Some arrow drifting not able to show correct position (while Google Maps and Apple Maps all work fine).
      I'm a bit frustrated as during motorcycle ride reliability is a key. Stopping and restarting navigation app it annoying. Hope you understand.
      • Jan 50undefined Offline
        Jan 50
        wrote on last edited by Jan 50
        On a Samsung SE21FE battery is not impoved. Phone stil gets very hot...
        Also the app stil crashes (see ticket).
          A hot/warm phone is fairly normal when navigating. It differs per app but all phones are getting warm/hot when navigating.
          But yes. MRA still uses on average still a bit more power compared to other apps. But it is a lot better than a few years ago.
          • henry van den beltundefined Offline
            henry van den belt
            Helaas, navigeren met mijn telefoon zorgt nog steeds voor een hoog batterijverbruik. Nieuwe accu, nieuwe laadpoort, nieuwe usb laadaansluiting, nieuwe laadkabel.
            Voorlopig gebruik ik MRA niet meer om te navigeren tot het probleem is opgelost. Ik heb lifetime abbonement dus dat zal ooit wel gebeuren, toch?
            Voorlopig is Kurviger aan zet.
            Kreeg tijdens mijn vakantie in Kroatië een lekke band met de motor. Toen ik ff wilde bellen dat ik met een probleem stond en het wat later werd bleek ik nog 16% accu te hebben op m'n telefoon. Dan wordt ik toch een beetje zenuwachtig
            • D Griffinundefined Offline
              D Griffin
              How do I tell what version I have? Will it automatically update me? or will I at least see a prompt?
              • D Griffinundefined D Griffin
                Peter Zehentreiterundefined Online
                @D-Griffin Open your account on your smartphone, scroll all the way down, and you'll see which version is currently installed.
                Currently, 4.4.0-404 is the latest version Android and iOS
                Updates will be installed automatically, provided you've allowed automatic app updates in the Play Store / App store
                BMW R 1250 GS
                BMW Connected Ride Cradle
                Pixel 9 "online"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                • henry van den beltundefined henry van den belt
                  @henry-van-den-belt said in New update! (4.4.0):
                  Dingen nieuw kopen is alleen een oplossing als je de juiste dingen koopt.
                  Gebruik je de MRA app met Carplay of Android Auto toevallig? Ik heb de indruk dat AA/CP connecties méér stroom verbruiken dan de MRA app zelf.
                  Een powerbank in je tanktas werkt goed tegen zenuwachtigheid 😉
                  henry van den beltundefined 1 Reply Last reply
                    henry van den belt
                    Yep., de accu van de telefoon was al wat ouder dus vandaar laten vervangen.
                    Niet perse omdat ik dacht dat daar het probleem in zat. En inderdaad had ik ook nog een powerbank bij.
                    Maar wat ik eigenlijk wilde zeggen is dat de app nog steeds behoorlijk veel verbruikt
                    Jan 50undefined 1 Reply Last reply
                      Jan 50
                      #19
                      @henry-van-den-belt ik heb ook deze ervaring met een Galaxy S21FE. Telefoon wordt ook erg warm wat denk ik vooral invloed heeft op de stabiliteit. Op vakantie, in de auto, de telefoon in de airco luchtstroom gehouden waarna de app wel redelijk stabiel was.
                      Heb in het ticket #55262 weer input gegeven. Zou fijn zijn als daar ook naar gekeken wordt (en een keer op wordt gereageerd).
                      Mzokkundefined
                      CD130undefined
                      Jan 50undefined
                      Jan 50
                      Hns_Brwrundefined
                      Hns_Brwr
                      Cookie On Tourundefined
                      Cookie On Tour
                      D Griffinundefined
                      D Griffin
                      henry van den belt
                      Gos Kuusundefined
                      Gos Kuus
                      Luk4s7undefined
                      Luk4s7
                      C.A. Kielen
                      • Please allow me to introduce myself....
                      • waar om kan ik geen kleine pontje in mijn route maken ondaks dat het uitm sta
                        Nick Carthewundefined
                        2.6k
                      • Feature request CARPLAY - add live search option while on active route
                        Allistonundefined
                        Alliston
                      • Route lines not showing
                      • PC to Android, display Route and Track together?
                      • Moduis "Fiets" Navigatie "Volg de lijn"
                        intercomundefined
                        intercom
                      • Fit to screen
