  3. [App] Announcements
  4. New update! (4.4.0)
New update! (4.4.0)
19 Posts 14 Posters 5.0k Views 5 Watching
  • Mzokkundefined Offline
    wrote on last edited by Mzokk
    Looking forward to trying it. I had 4 days / 900 miles 1500 km round Scotland last week using Android Auto on my Honda Africa Twin Adventure sports via a Motorola Edge 40 Neo and the (last iteration) of the app was faultless including routes designed with optional loops (no via points only shaping) two of which I skipped and the app continued perfectly after the next waypoint was encountered. I still have a Garmin XT mounted on the bike but its only used for custom proximity shown POI's and I run a confirmation track of the MRA route I'm running. Many thanks. Oh and it was 27C on Mull last Friday. Most unusual!!
    • C.A. Kielenundefined Offline
      C.A. Kielen
      I use the app every day during my current 4-month trip. Last month in Iraq, I put the phone in the driving wind to cool it down. As soon as I arrived in a city with the usual congested traffic, the phone overheated and started giving a less and less clear picture until it stopped completely. Just when you need it the most. So I am very happy that the problem is found and my phone no longer overheats. To prevent overheating it also helps a little if you stop charging the battery.
      C.A. Kielenundefined 1 Reply Last reply
      • Hns_Brwrundefined Offline
        Hns_Brwr
        ik ga morgen gelijk testen, 360km dus dat hoop ik te voltooien met mra
        • CD130undefined Offline
          Vandaag uitvoerig getest. Mooi op te zien dat de blauwe lijn nu gelijk loopt. Had wel meerdere keren dat de app vastliep rondom stops. Ik maakte gebruik van CarPlay.
            The battery usage is certainly improved. The phone was cooler today and less trouble to keep the battery charged. Good job.
              There is an Autozoom in Android Auto. I can clearly see this on my screen. But how it works? I don't know. It looks random.
              My setting is "Both" (speed and directions/crossings). Biggest complain. The crossing with a white arrow shows up in the screen only 120-140 meters before you arrive at the crossing. Too late.
              The blue line and position indicator are looking good. Did not see any strange things. Smooth graphics. Good job.
              There is still a clear delay in real position and position on screen. Combine this with the issue of the Auto zoom and you can understand there is an issue.
              What i noticed about the delay in the position indicator compared to other navigation apps.
              Other navigation apps are more on par with the real position. But when you take a wrong turn it takes those other apps a longer time before they noticed you took a wrong turn.
              It seems all navigation apps have the same issues but those other apps do a more aggresive correction to keep it the indicator better on par with your real position.
              • C.A. Kielenundefined C.A. Kielen
                C.A. Kielen
                Drove all day today. After 2 hours of driving 35% battery used. That is real progress. Phone stayed cool all day.
                • Luk4s7undefined Offline
                  Luk4s7
                  I posted my last weekend issues with app here https://forum.myrouteapp.com/post/67675
                  In short: still "eats-up" the route and crashes (after eating enough) 😉 Some arrow drifting not able to show correct position (while Google Maps and Apple Maps all work fine).
                  I'm a bit frustrated as during motorcycle ride reliability is a key. Stopping and restarting navigation app it annoying. Hope you understand.
                  • Jan 50undefined Offline
                    Jan 50
                    wrote on last edited by Jan 50
                    On a Samsung SE21FE battery is not impoved. Phone stil gets very hot...
                    Also the app stil crashes (see ticket).
                      A hot/warm phone is fairly normal when navigating. It differs per app but all phones are getting warm/hot when navigating.
                      But yes. MRA still uses on average still a bit more power compared to other apps. But it is a lot better than a few years ago.
                      • henry van den beltundefined Offline
                        henry van den belt
                        Helaas, navigeren met mijn telefoon zorgt nog steeds voor een hoog batterijverbruik. Nieuwe accu, nieuwe laadpoort, nieuwe usb laadaansluiting, nieuwe laadkabel.
                        Voorlopig gebruik ik MRA niet meer om te navigeren tot het probleem is opgelost. Ik heb lifetime abbonement dus dat zal ooit wel gebeuren, toch?
                        Voorlopig is Kurviger aan zet.
                        Kreeg tijdens mijn vakantie in Kroatië een lekke band met de motor. Toen ik ff wilde bellen dat ik met een probleem stond en het wat later werd bleek ik nog 16% accu te hebben op m'n telefoon. Dan wordt ik toch een beetje zenuwachtig
                        • D Griffinundefined Offline
                          D Griffin
                          How do I tell what version I have? Will it automatically update me? or will I at least see a prompt?
                          • D Griffinundefined D Griffin
                            Peter Zehentreiterundefined Online
                            @D-Griffin Open your account on your smartphone, scroll all the way down, and you'll see which version is currently installed.
                            Currently, 4.4.0-404 is the latest version Android and iOS
                            Updates will be installed automatically, provided you've allowed automatic app updates in the Play Store / App store
                            BMW R 1250 GS
                            BMW Connected Ride Cradle
                            Pixel 9 "online"
                            SPC Universal mount
                            Motorola Edge 40 "offline"
                            Sena SLR 3
                            Sena 50 R
                            • henry van den beltundefined henry van den belt
                              @henry-van-den-belt said in New update! (4.4.0):
                              Dingen nieuw kopen is alleen een oplossing als je de juiste dingen koopt.
                              Gebruik je de MRA app met Carplay of Android Auto toevallig? Ik heb de indruk dat AA/CP connecties méér stroom verbruiken dan de MRA app zelf.
                              Een powerbank in je tanktas werkt goed tegen zenuwachtigheid 😉
                              henry van den beltundefined 1 Reply Last reply
                                henry van den belt
                                Yep., de accu van de telefoon was al wat ouder dus vandaar laten vervangen.
                                Niet perse omdat ik dacht dat daar het probleem in zat. En inderdaad had ik ook nog een powerbank bij.
                                Maar wat ik eigenlijk wilde zeggen is dat de app nog steeds behoorlijk veel verbruikt
                                Jan 50undefined 1 Reply Last reply
                                  Jan 50
                                  #19
                                  @henry-van-den-belt ik heb ook deze ervaring met een Galaxy S21FE. Telefoon wordt ook erg warm wat denk ik vooral invloed heeft op de stabiliteit. Op vakantie, in de auto, de telefoon in de airco luchtstroom gehouden waarna de app wel redelijk stabiel was.
                                  Heb in het ticket #55262 weer input gegeven. Zou fijn zijn als daar ook naar gekeken wordt (en een keer op wordt gereageerd).
                                  CD130undefined
                                  Mzokkundefined
                                  Cookie On Tourundefined
                                  Cookie On Tour
                                  D Griffinundefined
                                  D Griffin
                                  henry van den belt
                                  Hns_Brwrundefined
                                  Hns_Brwr
                                  Jan 50undefined
                                  Jan 50
                                  Gos Kuusundefined
                                  Gos Kuus
                                  Luk4s7undefined
                                  Luk4s7
                                  C.A. Kielen
                                  • Anyone with CPMC B6?
                                  • MRA Fazit V5.0.2-438 Super
                                  • Maybe last tour this year
                                  • New beta! 5.0.2 (438) - free drive
                                    121
                                  • Sound issues in AA with MRA Navigation
                                    1.3k
                                  • MRA 5.0 - 420 Folge Modus so nicht nutzbar // Follow mode so not usable
                                  • GBD files into MyRoute
                                  • Just a little tweak
                                    Richard 18undefined
                                    Richard 18
