  4. Problems with the "Avoid Toll Roads" option
24 Posts 7 Posters 9.5k Views 3 Watching
  • Donovan Smith Offline
    Donovan Smith
    I planned it on the web through the web app. So can I assume the web app is osm ? I know the the Next App is here maps.
    Brian McG 1 Reply Last reply
    • Donovan Smith Donovan Smith
      Brian McG Offline
      Brian McG Offline
      @Donovan-Smith the navigation app on your mobile uses the Here routing algorithm
      the Here algorithm is the one used for navigation by MRA
      on the Web planner when you are planning you can choose which routing algorithm you wish to use either OSM, TomTom or Here
      You should choose the algorithm that matches your navigation device
      So if your using MRA or a Garmin to navigate it is best to use the Here routing algorithm
      If your using a TomTom obviously best to use the TomTom algorithm
      If your using Osmand then best to use the OSM algorithm
      The TomTom & Here routing algorithms are not available with a basic web account, you need either a Gold or Navigation subscription to access them
      The map layers are just graphic overlays they just show you where the roads are, they are not responsible for calculating the routing
        Donovan Smith
        @Brian-McG ok. I just looked on the mra route planner. I don’t have access to choose here maps as I am not a gold subscriber. I am only paying for the next nav app. So by default following your post I am guessing I am on osm maps then when I go to my nav app it’s here maps, so that’ll be the issue! If I plan a route using destination input, is that also using osm maps to plan? Vis a vis is there a way around (simple and easy ) or is this a way they force a revenue stream?
        Nick Carthew Brian McG 2 Replies Last reply
          Nick Carthew Online
          Nick Carthew Online
          @Donovan-Smith said in Problems with the "Avoid Toll Roads" option:
          An MRA Navigation Next subscription gives you access to the HERE planning map in the website route planner.
            Brian McG Offline
            Brian McG Offline
            @Donovan-Smith if you look at the first image in my previous post you can see it says "Here (MyRouteapp/Garmin) Gold / Nav"
            the "Nav" at then end is to indicate, as @Nick-Carthew says that the Here routing is available with the navigation subscription
            You need to be logged in to the web planner with the same account that you use for the Navigation app
              Donovan Smith
              Ok. Found the here maps setting. Thank you. Next question, if I create a a to b route on the web in the here maps. Does it always open in here maps afterwards when I choose to edit it?
                Nick Carthew Online
                Nick Carthew Online
                All routes will remember the last planning map that was used for that route.
                If you click Always use this map for new routes, the HERE planning map will always be chosen for new routes.
                  Donovan Smith
                  Thank you @Nick-Carthew. So I guess then I can open and edit it in the mra app and it will do as expected. I have created a simple route here just a to be to avoid tolls. Can someone confirm it’s good please?
                    Nick Carthew Online
                    Nick Carthew Online
                    @Donovan-Smith You'll need to share the route before anyone can check it.
                    To share:
                    Firstly, the privacy of the route must be set to Public.
                    Open the route and then open the Route-information tab in the left menu column, here you'll see a Privacy drop down box where you can change the privacy to Public.
                    Now click the Share button in the top right of the map screen, if you do not see a Share button, click Page menu first, then you’ll see Share button.
                    After clicking Share, you have different options for sharing, choose the Link option and then copy and paste the URL web address into your reply please.
                      Donovan Smith
                      https://www.myrouteapp.com/en/social/route/11950009?mode=share
                        Brian McG Offline
                        Brian McG Offline
                        @Donovan-Smith that is a long A-B route, just shy of 600 miles
                        it seems to be doing the right thing in avoiding the tolls
                        I put similar start - end points in google maps & selected avoid tolls & the 2 systems seem to track pretty well
                        a few small differences, the main one being how to route round the tool on the A63 at the Aire Port des Landes, only about 35 miles into the trip
                        If you select the TomTom & Openstreetmap route algorithms you will see they also take slightly different paths but in general they are all doing similar things
                        Remember to return the route algorithm setting to Here before you navigate
                        Giancarlo e
                        Giancarlo e
                        Donovan Smith
                        Donovan Smith
                        Manzo91
                        Manzo91
                        • Garmin XT2 - losing my mind!
                        • Export to BMW CRN
                          684
                        • Update 5.2.2 - Quick fix
                          868
                        • NC500 glitch
                          3.0k
                        • MRA Beta V6.x - und Beta Webplaner 2.0 vielleicht bald
                        • High Contrast Maps
                          TuonoPants
                          TuonoPants
                          1.7k
