  4. Petrol stations
Petrol stations
27 Posts 9 Posters 9.7k Views 5 Watching
  • Spiliundefined Offline
    Spili
    How to find a Petrol Station ALONG my route?
    All I can find is closest one - but not on my way.
    Could be perfect if there was a "indicator" showing distance to next petrol station ALONG a route.
      Spili
      Perfect solution has Sygic. Shows 2 petrol stations along a route.
      You know you should tank a bike now or on next station.
        Spili
        Even 3 next stations 馃檪
        Perfect solution.
        • richard 3vundefined Offline
          richard 3v
          Then use Sygic and not MRA.
          Problem solved!
          Spiliundefined 1 Reply Last reply
          -2
          • Spiliundefined Spili
            Perfect solution.
            @Spili Open your route on the Website (Routlab)
            Open route details, open POIs, select Gasstation.
            Zoom in to find Gasstations along your route.
            You can create a Poi for the Gasstation or a Waypoint with a symbol of a gasstation.
            BMW R 1250 GS
            BMW Connected Ride Cradle
            Pixel 9 "online"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
            Spiliundefined Bouke Entundefined 2 Replies Last reply
              @Spili, the gas station tile in the MRA app actually DOES show gas stations along or very CLOSE to your route.
              If you don't see it, it might be that there is none along or close to your route for many kilometers, OR that you do not have that option enabled in the app settings. It's in the functional settings menu.
              • richard 3vundefined richard 3v
                Problem solved!
                Spili
                @richard-3v Thanks for great advice. I want to MRA be better. Do not waste your time for such a post.
                richard 3vundefined 1 Reply Last reply
                  Spili
                  @Peter-Zehentreiter This is not solution DURING driving.
                    richard 3v
                    @Spili said in Petrol stations:
                    OK then, use MRA using the Next app, not using AA or CP. Then you will see the icon as @Con-Hennekens refers to and your roblem is solved.
                    Or have I wasted my time again??
                    • Bouke Entundefined Offline
                      until now it is not supported in AA/CP. only in MRA Next app direct on phone or tablet you will see a petrol station notivication. this is ask before but then the answer was limitation on AA/CP. but good question if it works on sygic and not on MRA Next on AA/CP.
                      i hope the developmentteam can put it on the request list.
                        @Spili, I am sorry, in my earlier comment I left out that you are using an AA/CP device, obviously noticable in your screenshots... I believe the tile I mentioned is indeed not visible on AA/CP devices, because of restrictions bij Google and Apple. There is a limit to the available information on such devices, to keep them from being a distraction. MRA choose other info and buttons to be visible. Maybe something can be changed about that in the future.
                          @Peter-Zehentreiter said in Petrol stations:
                          in case of a A2B or on the fly in the app offline this is difficult to do.
                            If you have a list of Fuel stations in your POI library, select the profile icon and the fuel POIs will be visible in all of your routes when planning and when you are navigating.
                            Spiliundefined Guzzistundefined 2 Replies Last reply
                              Spili
                              @richard-3v Unfortunately again 馃檪
                              There is reason I posted it in AA/CP section 馃檪 Not in MRA/Next section 馃檪
                              • Bouke Entundefined Bouke Ent
                                Spili
                                @Bouke-Ent
                                There are restriction on AA/CP side?
                                I do not think so because my screenshots are from Sygic running on Android Auto.
                                Maybe MRA has any limitations we do not know?
                                Bouke Entundefined Con Hennekensundefined 2 Replies Last reply
                                  richard 3v
                                  wrote on last edited by richard 3v
                                  馃榾 Fair comment ! 馃榾 馃憤
                                    Spili
                                    @Nick-Carthew Yes. I know I can plan my fueling.
                                    But it is not a solution I need.
                                    All I need is a icon or two with incoming petrol stations.
                                    Then I know I must tank now or I can go and tank on next station.
                                      @Spili My suggestion does not involve planning, it just shows fuel stations while you are navigating. You decide you need fuel and you ride to the nearest.
                                        @Bouke-Ent
                                        @Bouke-Ent
                                        i also have no idea but that was said last time there was this subject. i had same doubt and for me i was one of more reasons to dump AA/CP for now and use phone or tablet.
                                          @Bouke-Ent
                                          Yes there are restrictions, I don't think so, I know so.
                                          What reason do you think MRA would have to cripple the AA/CP interface like that?
                                          Your screenshot from Sygic clearly shows it has much less clutter by buttons and info tiles on it's screen. They clearly choose different things to show than MRA did, but they cope with the same limitations.
                                          Bouke Entundefined 1 Reply Last reply
                                          With your input, this post could be even better 馃挆
                                          Bouke Entundefined
                                          richard 3vundefined
                                          richard 3v
                                          Spiliundefined
                                          Spili
                                            Thomas Neumeyerundefined
                                            Thomas Neumeyer
                                            4.2k
                                          • New enlarge fuelstation icon gone to soon or not?
                                            Bouke Entundefined
                                          • Best way to set my Garmin Zumo XT to play well with the MRA?
                                            Travellexxieundefined
                                            445
                                          • Update 5.1.0
                                            Eric Col贸n 3 0undefined
                                            Eric Col贸n 3 0
                                            ginoginoundefined
                                            ginogino
                                          • Navigation arrow still not stable
                                          • Altitude does not match
                                          • V5.1.0 - 462 New altitude/heading shows incorrect Data
                                            J枚rgenundefined
                                            J枚rgen
                                            628
